Thread: Pump size help
    Feb 2016
    Springfieldwv
    2
    Pump size help
    I bought a Coleman 18x9 pool last year and the pump that came with it really sucks!! I want to purchase a new one but not really sure on the size to get. I heard the "sand" filter pumps are the best just not sure!! Any help will be appreciated.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump size help
    What was wrong with the pump?
    Mark
    Feb 2016
    Springfieldwv
    2
    Re: Pump size help
    When it would run it it seemed like it was getting clogged and not run right. It wouldn't "bubble" it just seems like it's to small for the pool
    Jun 2014
    15,103
    Re: Pump size help
    Clsand32, we had a similar question/post this morning. Maybe THIS THREAD will help you. If not, Mark (mas985) can certainly help you. Welcome to TFP!
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump size help
    Quote Originally Posted by Clsand32 View Post
    The smaller pump/filter combos can easily get clogged with an algae outbreak which is why I asked the question. Pumps and filters are not meant to remove live algae and changing pumps may not solve your problem if that is the reason the pump is not working well.
    But the pumps in the thread TS posted are good choices.
    Mark
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pump size help
    It is not so much that the Intex sand filters are great quality filters, it is just it is hard to beat their bang for the buck, particularly when you can get then from Amazon starting around $150 with pump. Having said that I suspect it will be a major improvement over your existing pump/filter combination, however no amount of filtration will make up for chemical imbalance and algae growing in a pool. So if you have cloudy water look first to your chemistry not to your filtration. See Pool School - Pool School
