Thread: Acid Question
    Dec 2015
    Sacramento California
    12
    Acid Question
    Hello Everyone
    I can seem to find the answer for this. I use the Pool Calculator to get amounts to add for LC and MA. Normally I dont fill everything out but today I noticed the amount of MA to add changes based on the TA level (if I write TA as 60 it tells me one amount, if I put in 90 it says another). Why is that?
    Also. Is TA suppose to be between 60-120. And CH between 220 and 320? I hear conflicting things here
    Here are todays numbers let me know if you think all is on track
    FC 5
    CC 0
    PH 7.9 (added to lower to 7.5)
    TA 90
    CH 275
    CYA 40
    Thanks
    Build Date 11/18/15 - 14K IG Gemstone (Pebble) pool, Hayward EcoStar Variable Speed Pump, 425sf SwimClear Cartridge Filter, Polaris 280 Pool Sweep with Booster Pump, Hayward Command 4 control system, GVA-24 Actuator, LED Light, Water Fall
    Jun 2014
    15,148
    Re: Acid Question
    We always use the Pool School - Recommended Levels to verify what our levels should be. A couple of the items changed last season, so it's always good to check for accuracy. It's best to fill-in all the parameters on the Poolmath calculator since some items can/do influence each other - even the water temperature. In simple terms, we know that TA serves as a buffer for pH, so it's easy to see how those two can relate - to include their side-effects on your CSI if you're in an area with exceptionally hard water (calcium). All-n-all, your numbers look very good.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,387
    Re: Acid Question
    MA lowers TA and pH. For a manually chlorinated pool you don't want TA to drop below 70. SWGs tend to raise TA and pH over time so they can go as low as 60 for TA. As to how high TA should be that depends on your circumstances. Usually we only worry about TA when pH is unstable, CH is over 400, or TA has dropped below 60.
    You want to adjust TA when pH is unstable to help prevent wide swings in pH readings. This tends to happen when TA is low. Also we recommend lowering TA to the 70-90 range if CH is over 400 to reduce the risk of calcium scale formation. Keeping pH and TA lower prevents calcium scale in high CH concentration water when replacing the water is not practical. If you TA gets too low, say below 60 that is when you will see unstable pH readings, or pH that drops below 6.8.
    Poolmath is designed to account for different variables for the values that can affect other values when adjusted. Since TA is lowered by adding MA, putting in your actual test result is going to give a different recommendation than leaving whatever the last test result entered will give.
    Love TFP? Become a
    TFP Supporter!
    Dec 2015
    12
    Re: Acid Question
    Thanks Everyone
