Results 1 to 7 of 7
Thread: Pump relay
    Pump relay
    My pump was running non stop. I have a jandy rs4 in do. I replaced the pump relay as the trip lever would not disengaged and the voltage was always 220v. Now the programming from the indoor controller will not operate the pump automatically. Any ideas?
    Richard
    Re: Pump relay
    Is it in Service Mode?
    Support the site
    Re: Pump relay
    It is not in service mode
    Re: Pump relay
    Go through configuration to make sure that everything is properly configured. Pump type etc.
    Support the site
    Dec 2014
    Riverside California
    482
    Re: Pump relay
    Do you hear a clicking sound when you energize the relay?
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Pump relay
    I'm assuming that you turned the breaker for the motor back on when you were done replacing the relay, yes?
    Factory Warranty Station for:
    Feb 2016
    Spring/TX
    57
    Re: Pump relay
    Did you hook the wire from the relay to the board where it says filter? (assuming it was your filter pump)
    Did you wire the pump to the line side with the power lines hooked to line too? (that'll cause it to always get power)
    If you have an older RS4 there is a 9v battery hooked to the board to maintain it's memory of schedules and etc when power is cut off from the board... so if that battery is dead you would have to re schedule it.
    If you have power running to it and schedules set and it's in auto and you see the little piece on the bottom of the relay moving in and out while hearing a click... It means you can possibly have a bad board.
    40k Gallon Grecian true L Gunite Pool/Spa. Clean clear plus 520 cartridge. IntelliFlow VS-3050. Polaris booster pump w/ Polaris 360 cleaner. Silencer 1 1/2 hp Blower. Aqualink RS8 w/ Iaqualink 2.0 upgrade kit.
