Thread: SWG / PS-4 cleaning time clock question
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    SWG controlled by Aqua Logic PS-4. When a temporary power interruption to the panel occurs, does that reset the memory clock for the salt cell cleaning reminder function? My assumption is that the board has a memory chip that retains the settings, but does that also retain the clock that tracks SWG usage?
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: SWG / PS-4 cleaning time clock question
    I would assume so. Manufacturer needs to take power outages into consideration when engineering that reminder. Otherwise, in some areas, you would never get a reminder.
    Factory Warranty Station for:
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Quote Originally Posted by Pool Clown View Post
    I agree, it is a reasonable assumption that since memory is retained for the pool's other settings (timer, clock, etc) when power to the panel is interrupted, the memory for SWG useage would be as well. Might just be my imagination that its been a longer than usual interveal between that yellow service indicator light coming on. I'll probably give it a few more weeks to see if the service light appears - if not, I may just clean it and then gauge how long it was before the service light come on. If its more than, say, 5-6 weeks before I see that ligfht, I may have my suspicions.
