Thread: Possible Weak Flow Causes?
    Dec 2014
    Clayton, CA
    22
    I am in need of help in diagnosing the cause of weak water flow. About two months ago I cleaned my filter assembly, after which I noted two things: (1) my flow increased somewhat and (2) the air relief valve pressure indicator on top of the filter went from 20 psi to zero. Since then my flow has been decreasing and it is now quite weak -- to the point where I can no longer effectively vacuum the pool. Suspecting a suction side air leak, I cleaned out the pump basket and re-seated the lid. That did not help -- the flow remained weak. When I restarted the pump, it was unable to push water out of the air relief valve on top of the filter, but water was flowing through the system.
    Is there any reason that this could be caused by something I did wrong in cleaning and reassembling the filter two months ago, or is this definitely a suction side air leak?
    Two other notes that may be relevant:
    1) I have only had this pool for 1.5 years, but during that time I have noticed that the water in the pump basket never stays at the lid even when the flow is good. I have always wondered if this was normal...
    2) When I cleaned out the pump basket, it was actually quite full of leaves and whatnot, yet the air relief valve pressure indicator on top of the filter was still at zero.
    Your thoughts on this topic are greatly appreciated!
    Thanks in Advance,
    -J Phresh
    26K gal, IG Pebble Tec, 2 HP Jandy Pump, 420 sqft filter (Durex Triton C&C Plus with 4 PCC105 Pleatco filters), Barracuda G3 Vacuum, build date unknown, using Taylor K-2006 Test Kit.
    Oct 2015
    Katy/Texas
    411
    Re: Possible Weak Flow Causes?
    It may be that you have debris stuck in the pump impeller. Can you open the pump case to inspect the impeller.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Yes, there could be some issue with reassembly. I believe the name of the filter is Purex Triton, now Pentair Clean and Clear. Check here to see if this is it. There are manuals and exploded parts diagrams available here, PENTAIR Cartridge
    More here on finding a suction side leak, Pool School - Suction Side Air Leaks
    Dec 2014
    Clayton, CA
    22
    Excellent suggestion WASP! As it happens, that was the issue... I checked the impeller and there was all kinds of debris in there. Once I got it cleaned out, the flow went back to normal! The pump was able to easily push water out of the air relief valve on top of the filter, and the pressure indicator on top of the filter now reads 10 psi. Thanks for your help!
    DFW, TX
    24,450
    Good news! Thanks for the follow up.
    Oct 2015
    Katy/Texas
    411
    Glad we solved your flow problem. Since you found debris in the impeller, carefully check the pump suction basket and make sure there are no cracks. That stuff got past it somehow.
