Thread: Don't wanna re-paint fiberglass pool every year...Other options???
    Feb 2016
    Albuquerque, NM
    2
    Hello all...
    I just bought a house with a fiberglass pool last October. House built in the 1970s, and I'm assuming the pool is too (but not certain.) The paint on the pool (no idea if it's epoxy or what) is flaked off about half of it.
    From what I'm being told, painted fiberglass pools have to be re-painted every 1-3 years. Made some phone calls and haven't found a pool company that will paint it, won't paint it myself, and want a more lasting solution to the problem.
    What are my options? Any way to re-finish/re-texture, so the paint won't peel?
    Should I consider it a hole in the ground and start from scratch? (I.E. Remove the old fiberglass and go with another material? Will cost monstrous $$ I imagine.)
    Suggestions? Thanks in advance
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Don't wanna re-paint fiberglass pool every year...Other options???
    Welcome to TFP, congrats on the new pool!
    Pool paint usually doesn't last more than a year or two. Fiberglass pools are usually resurfaced with gelcoat. I was doing some research about resurfacing fiberglass and ran across this, Fiberglass Pool Resurfacing and Refinshing, it looks pretty interesting and it is DIY.
    DFW, TX
    24,502
    Somebody just posted about resurfacing their FG pool on this thread, Need paint help - 'glass pool
    Nov 2011
    Moberly,MO
    1,010
    ecofinish has a thermally applied plastic finish that would work to redo your pool
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Feb 2016
    Albuquerque, NM
    2
    Thank you all for responding I appreciate it so much.
