Results 1 to 10 of 10
Thread: I'm Getting White Cloudyness
    Jun 2014
    Roseville, CA
    345
    Bor 80*
    Cl 5.5
    CC 0.0
    CYA not measured. Ran out of reagent
    Ph 7.6
    TA 50
    CH 400
    Salt ~ 2600
    *We have been getting a lot of rain and I'm surprised the boron is so high, considering salt has dropped considerably due to dilution... Hmmm....
    Anyway, I tried some clarifier and that didn't help. It still early in the year to bring everything back up to spec's, but I'm concerned about the cloudiness.
    Ideas?
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Jun 2014
    15,268
    Re: I'm Getting White Cloudyness
    Hello Roseville. Well, something that is critical for us is the CYA and FC. It's very possible that your cloudiness is related to an algae bloom, and that your CYA (stabilizer) and free chlorine are not balanced properly. Hard to tell at this point. I certainly wouldn't waste any more money on pool store products until you get the CYA reagent and post the FC and CYA. Posting CC will help as well. I suspect that will be key to finding the source of your problem.
    Now I just realized you have numbers in your sig (maybe older tests?) If we were to assume your CYA is up around 75 (round up to 80), your FC target is 6 for an SWG pool. You might be right on the border of low chlorine (FC). I would really like to see those most real-time numbers (FC, CC, and CYA).
    Jun 2014
    Roseville, CA
    345
    The numbers in my sig are what are recommended.
    I mislabeled FC as CL - it's 5.5 CC was zero
    EDIT:
    BTW, isn't an algae bloom green? Mine is white/milky and actually fairly minor as I can see the bottom ok.
    My Ideal Specs:
    Jun 2014
    15,268
    The start on an algae bloom isn't always green. Cloudiness can in-fact be the beginning of trouble. We see it all the time. But I would like to point-out one thing you noted in your last reply. According to the Pool School - Recommended Levels and Pool School - Chlorine / CYA Chart, your SWG CYA should be between 70-80. Too low and your SWG works too hard to maintain FC. Too high and you may not make enough FC. Some of your other signature recommended levels have changed recently on our site, so you might want to double-check those.
    If we knew your CYA was between 70-80, your FC is fine. But with an unknown CYA, that's really difficult to confirm. Is there any way you can expedite an order of R-0013 reagent? We know the pool store CYA testing is horrible and typically inconsistent, so I don't recommend them at this point. Other than the unknown CYA, your other test readings look rather good. I'm actually surprised to see your CH at such a reasonable level for CA.
    Jun 2014
    Roseville, CA
    345
    I'm ordering reagent. And I dumped in 3/4 gal pool bleach.
    My Ideal Specs:
    Jun 2014
    Roseville, CA
    345
    New accurate numbers 2/22/16
    Pool = 14,000 gallons
    Temp 60F
    FC = 7.0
    CC= 0.0
    PH= 7.6
    CYA= 75
    TA = 75
    CH= 375
    Salt = 1600 per SWG instant reading
    Borate when I closed the pool = 50. My guess today is ~ 30
    CSI @ Pool Math = - .42
    I added Chlorine a day or so ago, and it seems better and only slightly cloudy.
    I'm concerned about TDS (total dissolved solids) and having to drain water and dilute my chemicals.
    I think the borate number is high. I tested my strips in tap water, and it went one color above zero borate. Tap water should be zero. So my strips are not accurate.
    My Ideal Specs:
    Jun 2014
    15,268
    I wouldn't worry to much about the TDS. Your overall numbers look quite good. Getting that FC up to match your validated CYA range was ideal. CSI is a bit in the negative, but a bit early to be concerned as I suspect low water temps could be a contributing factor there. I would continue to do what you are doing and simply watch the water clarity. If things take a turn for the worse in the future, you can always do an Overnight Chlorine Loss Test to see if there are any active organics consuming your chlorine. Pool School - Perform the Overnight FC Loss Test (OCLT) Good job.
    PS ~ Don't forget to update your sig numbers at some point so you don't get thrown off track.
    Jun 2014
    Roseville, CA
    345
    I'm really not sure what to put in sig numbers. Ideal, actual, or recommended?
    My Ideal Specs:
    Jun 2014
    15,268
    Actually, most of us don't put the recommended numbers in there. We have a TFP link/page for that, or we print it out and leave it with the test kit. Just enter your pool info, equipment type, basically some of the things you already have listed. Maybe add the type of pump, make, model, things like that, and anything else you may be using. If it were me personally, I'd just remove the chemical reading info from your sig and use that extra space for describing anything else about your pool that you think may help readers. Once you see a variety of other posters' sigs, you'll see a common theme.
    wjr75's Avatar
    Jun 2013
    IL
    836
    You may have a rip in one of your cartridge filter pleats. It happened to me last summer.... all readings were good but got cloudy. Bought some new filters which fixed the problem in my case. Did you see a slight drop in your filter pressure when this started? I had about a 1.5 psi drop when the problem started.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
