Thread: TA getting too low
    setsailsoon's Avatar
    Oct 2015
    Stuart/FL
    467
    TA getting too low
    folks,
    So I've been delighted with my TFP and have been learning a lot since last Nov when I joined. We use our pool a lot even in winter since we're in S Florida- solar/gas heaters spoil us! All test results have been in range using my TF-100 except TA has slowly been creeping down from 130 to a new low of 50 yesterday. I've never adjusted this number but read up on it last night, got my 12lb bag of Baking Soda at WM and added about 1/3 of the amount required to get back to 100 (40 oz by vol). Seemed to dissolve well (pH and FC adjusted yesterday). I'm hoping this goes as well as the other adjustments based on the Pool Math Calculator... they're always spot on! So here's my question. The PM Calculator shows this baking soda addition will increase the pH a LOT (~.8) but I've read that careful addition in small amounts will reduce this. I'm ready to make large pH reduction if needed (in small increments of course) but is there anything else to do other than just monitor the pH and make acid addition as appropriate?
    Any comments would be appreciated. This is my first time with TA adjustment and I'd like to be sure my plan makes sense to you experts.
    My most recent test results are shown below. Please note I've used trichlor to chlorinate for the past 2 months to increase the CYA and it looks like I'm getting close to target so I'm now back to 10% bleach. I'd like to be on the low end so I can use tablets when needed later this summer for extended travel without getting too high on CYA.
    Chris
    Date
    TA CYA FC CC CH PH Actions/Observations
    14-Feb-16 60 50 6 0 275 7.7 Rain
    15-Feb-16 Rain
    16-Feb-16 60 50 6 0 275 7.6 Big Rain! Then Sunny later, removed remaining trichlor
    17-Feb-16 5 0 7.7 Sunny!
    18-Feb-16 3.5 0 7.8
    19-Feb-16 50 3.5 0 7.8 readings left 7 am Added 12 oz Muratic, 16 oz bleach, 8pm 4.5 FC pH 7.5
    20-Feb-16 50 4.5 0 7.6 Added 40 oz Baking Soda
    -Chris-
    2013 In-ground plaster/pebble, screen enclosed, 12000 gal w/ Jandy 2 speed 1 HP pump, Jandy CS 200 cartridge filter, 800 gal spa w/ 1.5 HP booster pump, Solar heater, 2 LED lights in pool 1 light in spa, TF-100 test kit, The PoolCleaner Next Generation, Jandy RS-12 Automation system with iAqualink 2.0 control, Separate Hayward/Goldline Solar control
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: TA getting too low
    Trichlor is acidic and is probably helping to lower your TA. I wouldn't raise TA much above 60 or so and then wait to see how your PH acts. If PH remains stable then leave your TA wherever it lands between 60 and 80. What is the TA and PH of your fill water?
    30,419
    Baking soda typically has very little affect on pH. Recheck your calcs. If you get the same thing, post back and give us ALL your parameters that you have input.
    Oct 2015
    Stuart/FL
    467
    Dave,
    You're absolutely correct, I had the calculator set to Washing Soda instead of Baking Soda. The results I got were almost exactly as predicted.
    As always, thanks so much for the help!
    Chris
    -Chris-
    Jun 2014
    15,103
    Good one Chris. It's good to do that from time to time - just to keep Dave on his toes.
