Results 1 to 7 of 7
Thread: Applying for Permit (Owner Build)
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    I'm looking at my county's application for a swimming pool permit and I notice that it asks multiple times for information on the pool contractor. For an owner build would I just put down "self"? Has anyone had any issues with that holding up the process of approval?
    Nectarologist's Avatar
    Apr 2015
    New York
    426
    Re: Applying for Permit (Owner Build)
    Hi. I have not personally. They likely want to know to be sure it's being done by licensed people. I would put "no general contractor" and list the subs and what they will do (at least for the major stuff). Or you could put "homeowner" as the contractor but they may still ask about subs then. I don't think it would hurt to list the subs. If time is an issue it can only help.
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    Apr 2013
    Sacramento, CA
    2,769
    Don't list the subs unless they ask. Just put self. If they want more they will explain what they want at the counter. Go in and ask questions over the counter and expect to fail once.
    Sep 2015
    Austin, TX
    144
    A couple additional thoughts: "self" or your name is good. I'd recommend your name. I had to get a permit in Austin, which a notorious bureaucracy. They didn't give me a hard time at all. Also, the only subs they ever cared about were electrician and plumber.
    Another thing to note is that in most places (definitely throughout Texas), the rules are a lot more lax for homeowners. For example, I was able to pull my own plumbing permit because it's my house. There are exceptions (like working with gas always requires a license), but by and large, homeowners can get away with more. The permit people were also super helpful for me, even walking me through the whole scale process for the plot plan. The permit place also had a business center where I could print on the big plot plan size paper (11x17, I think).
    Other than waiting for a long time and getting the drawings to scale, the process was pretty painless. I was worried about what exactly needed to be shown on the plans, but it seemed they really just needed to see the survey (house and lot) with a rough shape of the pool in its location. The only specs they cared about were measurements. Every county will be different, but for Austin (a difficult government), it was relatively painless.
    Quote Originally Posted by gwegan View Post
    I was also really worried about failing, but I didnt. Even if I did fail, you get a specific list of things to fix and meet with a person before submitting again (in Austin). Don't know if it works the same in GA.
    Construction underway.
    33x23 freeform 16k gallon IG pool, pebblesheen, SWG in Austin, TX
    Pentair 3HP VS pump, Hayward 30" sand filter
    Build thread: New Austin, TX Owner Build
    Jul 2014
    Milwaukee, WI
    4
    In Milwaukee, WI where I live, the suburb that I am in requires licensed contractors to pull most permits. I already have a pool, but want to renovate the whole pool area and want to do much if it myself, minus some of the plumbing and electrical. Any suggestions on how to get around that?
    freeform 22k gallon IG pool in Milwaukee, WI
    Pentair 3HP VS pump, Hayward sand filter
    Jan 2016
    TX
    157
    Quote Originally Posted by kleinmk View Post
    Don't tell anyone you are renovating... OR ask a friend with a contractors license to pull the permits for you OR get licensed with the state
    Gunite Pool/Spa, CLI Caribbean blue crystal stone smooth, Pentair 3hp Intellifo VS, Pentair Quad DE Filter, Pentair 400k BTU Heater, KK Prowler 820, Pentair PSL4 controler with Screenlogic wifi, Inline Chlorinator, Pentair 1.5hp Spa Blower, TF-100 Test Kit w/ Speed Stir. My 2016 Pool Build
    Apr 2013
    Sacramento, CA
    2,769
    If they require licensed contractors for most permits I would go ask. Don't call go down and talk over the counter. I suspect they want a licenced electrical contractor and maybe a plumber. But if the plumbing is just pool plumbing they may waive that.
