Thread: Warranty work
    Dec 2015
    Cypress, Texas
    57
    Warranty work
    My pool needs to be drained so the plaster can be fixed. I don't feel I should have to pay for the refill since the plaster company has to fix their mistakes, anyone have experience with this?
    16,388 gallons, IG, Pebble Sheen, Pentair Clean & Clear Plus cartridge filter, Pentair Whisperflow Pump, August 2015, Taylor K-2006, spa
    Mar 2014
    Angleton, Tx
    91
    Re: Warranty work
    dealing with it now.. big company from Houston. Looks like ill be eating the price for a fill and start-up.
    IG Pebble sheen blue surf approx. 14k gallon, beach entry, 7' spa, 3.5 ton jumping rock/waterfall, Pentair 2hp whisper flo, booster pump, 520 cartridge filter, Stenner Econ T, 400k master temp heater, easy touch controls,TF-100 w/speedstir
    Nectarologist's Avatar
    Apr 2015
    New York
    428
    Re: Warranty work
    No experience personally. Refer to the terms of the warranty. If it's silent on this I'd invoice them for the cost of the water. It's implied that you would have to drain water to repair the plaster under it. I doubt it's worth going to small claims court over but most states are friendly to consumers when there is ambiguity in what a warranty says. Too many contingencies to explain here but start with the warranty document they gave you. If none then check with your state's division of consumer affairs regs since that will govern (and may regardless of what their document says).
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
