Results 1 to 16 of 16
Thread: Big Hole
    Feb 2016
    Waynesboro, Pa
    6
    Big Hole
    My pool is concrete block that is all tile. I found a bad area that was leaking after removal of tile found roots have grown up through the cavity of the block. It has created a large hole and crack on the block inside, plus cravity is void of dirt and cement mush. Just looking for a few suggestions.
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Re: Big Hole
    No suggestions - but wow, so sorry!
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Big Hole
    OH NO! Do you have a few pictures of the hole and area so we can see what we are working with?
    Kim
    Apr 2013
    Sacramento, CA
    2,769
    Re: Big Hole
    Some overall pictures of the pool and some pictures of the problem area woul be good.
    How old is the pool?
    Is it cement (gunite) ? If so does it have steel rebar as a reinforcing cage?
    Is it concrete block? Something else?
    Did you build it?
    Some more info and pictures will give us a start.
    Feb 2016
    Waynesboro, Pa
    6
    Hole in pool wall
    Concrete block wall with tile finish. Roots have come through and penetrated inside pool under tile and destroyed inside block cavity and put holes in the wall. Looking to fill with cement but what type. Any suggesting to fix are welcome. I live in a warm climate 70 is the lowest temp I have seen in years. So no issues with freeze thaw.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Hole in pool wall
    Welcome to TFP!
    If you are sure you have all the roots out of the cracked and broken area, I think you can repair that.
    You will need to get enough hydraulic cement from your local masonry supplier. A good thing to help with the sealing of the holes would be what I've always known as concrete bonding agent -- a white milky fluid you paint onto the surfaces of the concrete you are repairing.
    For the larger deeper holes, you can use a sand topping mix, essentially a sand and portland mix. Add just enough water to make a loose mortar then fill the spaces to within 2" of the surface. Complete the repairs with the hydraulic cement, then replace the lost tiles.
    30,431
    Re: Big Hole
    Usvipoolsteve,
    Ask your question in one thread only.....very confusing otherwise.
    I have merged them for you.
    30,431
    The type of concrete should make no difference......unless I am missing something??
    It is important to "pin" both sides of the hole so new concrete will hold both sides together
    Apr 2013
    Sacramento, CA
    2,769
    Re: Big Hole
    As Dave says above you want to fill the void with concrete. Any good high strength concrete will do. Some would pin or staple the edges. I would try to eliminate the source of the roots
    Are all the blocks filled with concrete? Is there any rebar?
    Feb 2016
    Waynesboro, Pa
    6
    Big Hole
    Thank to everyone for the help.I am planning on spraying whole area inside with some ground clear plant killer. the only vegetation around is at least 20 feet away with poured concrete completely around pool. I am little concerned because the pool wall is about a 4 feet from the cistern wall. Need something strong to make sure whatever the plant is is gone. The tiny fibrous are in the concert block but detach from the main root that came through the back side of the block. The whole cavity of block where cement is poured down is vacant from about a foot under the light down. I Am planning to dig down further and vacuum the debris out. Do you think screwing wood to the face up to top big hole and pouring quick kreet mortar mix down to fills and finishing top hole with hydraulic cement?
    Apr 2013
    Sacramento, CA
    2,769
    Re: Big Hole
    You need a high strength mix. The tile provides the waterproof membrane so wether it's hydraulic cement doesn't matter. Does the pool have any rebar?
    Feb 2016
    Waynesboro, Pa
    6
    Re: Big Hole
    I haven't found any rebar. I thought there would have been. I went to the pool company that had been taking care of it and found they dove the pool for leaks in 2007 and put some A B epoxy In that area.
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Big Hole
    That is very interesting.........that suggest you might want to go a step further to fix it for good.
    Now what that step is I have NO idea!
    Kim
    Feb 2016
    Waynesboro, Pa
    6
    Re: Big Hole
    Think that would involve removing concrete blocks and replace them as well digging through deck and to get to back of wall. I have been working at getting ready to do the repair. I will post pic of progress and Finnish
    Apr 2013
    Sacramento, CA
    2,769
    Re: Big Hole
    Yea I've sat here and thought about what you could do to prevent re-occurrence. Nothing simple.
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Big Hole
    I look forward to seeing this. I am SO glad it is not me but sorry you need to do it......Do a step by step if you can so others can learn from you and what you are having to do.
    Kim
