Results 1 to 8 of 8
Thread: Dry pack inside pool light
    I'm just about to replace the engine/LED board in two intellibrite 5g color pool lights. One light lasted a year, warranty replacement lasted just over two years. The other went a little crazy for a while (out of warranty) before settling on one dim color. I was thinking about throwing in one of the little silica gel packs inside the light when I'm replacing the engine to hopefully suck up any moisture inside the light. Would this be dangerous due to heat build up inside the light?
    30k gal, IG Plaster, 520 sqft Cartridge filter, Intelliflow VS pump, Intellichlor IC40, Jandy AE-Ti heat pump
    Spa jets-Pentair 1.5hp pump.
    Water feature-Intelliflow VS, Hayward 120 sqft cartridge filter.
    Screenlogic, Intellibright LED lights, Pentair Easytouch control,
    New plaster, pumps, plumbing, solar panels and lights 11/2012.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Re: Dry pack inside pool light
    Did you get water in the lights that failed? Not sure if a silica pack would help. Never did something like that. It would more than likely void the warranty just because it is something in the can that the manufacturer did not put in there. Either way, i don't think it would take much moisture to max out that pack, then you would be in the same situation.
    Factory Warranty Station for:
    Quote Originally Posted by Pool Clown View Post
    There was no water in the light when I opened it, but the circuit board lines/circuits look corroded or moisture damaged
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    I don't think that is water. It almost looks like heat. Once moisture enters the fixture it isn't going to go. Unless you had visible moisture right when you opened it, that isn't from water. Something else is going on there. Is this less than a year, or at the time it began to act up?
    This is over a year old, roughly just over two years old. The first one died at 13 months.
    I replaced this one with an old Hayward pool light that we had, white only. I was just going to change both of them out for the simple white ones, but the other light cable has a collapsed or broken conduit under a concrete slab (one hundred foot run). So rather than break up the slab, its was change the engines.
    Pool lights are both 120v, all hot tub lights are 12v and have had no issues with the 12v.
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Wow.. didn't know you could just replace the circuit board. I'll remember that when one of my 3 5g lights bite the dust.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    JoyfulNoise's Avatar
    May 2015
    13,201
    I have some experience with PCB technology (I spent some time in a Cu plating lab that ran PCBs through it).
    That is not water damage. It's a poorly manufactured PCB. Either when they etched the lines or plated the various thru-vias, they did not rinse them properly. The wet chemistries used to manufactured those boards can become entrapped in voids in the materials there.
    You see how it looks like circular shaped blow outs along the trace lines? That is trapped plating solution in voids in the Cu trace lines. When the board heated up, the trapped solution will burst out. It will leak into the surrounding multilayers and create those circular patterns.
    It's a poor manufacturing process. So Pentair replaces the ones that go before the warranty is up but leaves you stuck with their bad product that's beyond the warranty. Hopefully they have seen this enough times to either correct it at the factory or dump the manufacturer and find a new one.
    Matt
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Good info.
