Results 1 to 7 of 7
Thread: coping - wide vs. narrow
    Jan 2016
    Mountain View, CA
    2
    Trying to decide between a wide coping (24" wide) vs. a narrow coping (4" wide). My pool deck will be travertine paver (versaille pattern) and the coping will also be travertine.
    Because I have a kidney-shaped pool, my PB is strongly recommending that I go with the narrow coping. He says wide coping only looks good on straight edge pool.
    Do others have any thoughts/experience on this? Appreciate any help/guidance!
    Jun 2015
    Mandeville, LA
    109
    Re: coping - wide vs. narrow
    Using wide coping on anything with much of a curve is going to give it a faceted look and will require a lot of wedge cuts.
    I'm doing 24x24 coping on mine but I only have a very large radius curve which won't cause much issue. With kidney shaped I don't think I would do anything wider than 12"
    Completed April 2016: 22x36 3.5-5.5-4 Inground, 17,500 gallons, Aquapure SWG, Jandy 2hp Variable Speed, Jandy 460 Cartridge Filter, Polaris 280, Aqualink PDA4, Jandy Nichless LED lights, Diamondbrite color Steel Blue, Noche Travertine Coping & Deck
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    I'm only giving my opinion based on my idea of the aesthetics rather than any hardcore rule of thumb.
    I think smaller is better to accentuate the kidney shape..... too large and it will overwhelm the pool.
    Go smaller.
    Aug 2014
    Houston tx
    2,525
    How good is the person cutting the stone?
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jan 2012
    7,364
    Another idea is to go on Google and look at other folks pools and see if you get any ideas from seeing other coping installs.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also keep in mind this is somewhat a fashion thing so think about which one will look less dated in 5 to 10 years
    Aug 2014
    Houston tx
    2,525
    Isaac that's a good point you make.
    Marla
