Results 1 to 11 of 11
Thread: Replacing pump motor/rebuilding pump/Newb help please
    Jul 2015
    TN
    11
    Have been reading and lurking for a while.
    The home I bought last year has a 20x40' inground liner pool. Salt/Forgot my controller/cell model.
    Pump is a Hayward SP3010X152AZ
    The motor is a Emerson/ Model #- R63CXDRE-239/ 1.5/.18 THP/1.0 SF
    Motor is two speed- 3450/1725 and 230V
    Also has a Hayward Sand filter but I did not take a picture of the model #
    When I bought the home I did not pay attention to the main pump motor leaking at the motor/pump seal. But it made through the summer and needs to be replaced. I have a separate booster pump for the Polaris cleaner, I believe it is 3/4 HP.
    I am having a hard time finding a cross reference for the correct motor. I am not sure about the square/round flange. I want to order a pump rebuild/seal kit to replace everything when I pull the motor.
    If anyone has suggestions on where to find a two speed motor like the one I need it would be great.
    Next I will be looking at either rebuilding or getting a new filter. The pool is about 8-9 years old. I am getting a little water leakage on the filter top by the spider valve.
    Thanks in advance for any links, or ideas. I am not really sure if I even have the correct sized motor and pump, because the homeowner before me seemed clueless about the pool. He just had it put in and called people when it did not work.
    hellstorm2004's Avatar
    Jul 2015
    Richardson, Texas
    182
    Re: Replacing pump motor/rebuilding pump/Newb help please
    A picture tells a thousand words! It would be great if you can post one.
    A quick led me to this...
    Emerson Pumps Emerson Pump Motors 888-445-0821
    See if you can compare your model.
    A.O. Smith pumps are great, if you want you can switch to them. Just remember the old pump might be jammed with years of use and rust and corrosion. I ran into the same problem when I changed mine last month. Had to call the pros.
    Purex Titron FNS DE Filter 25000 gallons approx.
    Century A.O. Smith B855 56Y 2HP Motor. 40x25 (approx). Plaster surface.
    TFT-100 Test Kit.
    Rainbow Lifeguard 320.
    DX5+S Cleaner.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Are you replacing the motor?
    If it's not making any grinding noises it's probably fine.
    For the seal kit, look up according to your pump model, not the motor itself.
    Dolphin E10 Cleaning Robot.
    Jul 2015
    TN
    11
    Going to be ordering a new pump motor in the morning. I have been reading reviews and researching motors for weeks. I am over thinking it, I think.
    Here is a motor that I found. Can anyone suggest anything different? I have my timer setup that when power is on, low speed is powered. When time clock is clicked on it goes to high speed. Using a two pole motor rated switch between GFCI breaker and timer as disconnect.
    I can can wire motor anyway it needs to be. But I feel like I am going to over pay for this motor. http://www.inyopools.com/Products/00...Keywords=B975T.
    Also will order a seal kit for Hayward SP3010X152AZ.
    Thanks for the help.
    Jul 2015
    TN
    11
    Just removed pump motor, impeller,etc. The shaft/mechanical seal that is ceramic needs replacing as well. These are not in a go kit? So would I just order a seal for a SP 3010?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Mark
    Jul 2015
    TN
    11
    Still,trying to decide where to buy from. INYO pool/ Leslie's /etc.
    anyone have site/store they trust for ordering parts/motors,etc?
    Will be be my first opening and will try the Slam from pool school.
    10 years of prior owner not taking care of things is making it harder on the. Thanks for the help in advance.
    20x40 inground liner pool.
    Hayward SP1030x152az pump
    1.5 HP two speed pump.
    polaris 3/4 HP booster pump
    SWG and controller
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Inyo is good and Sunplay.com is good.
    Jul 2015
    Richardson, Texas
    182
    PoolSupplyWorld/Leslie/Sunplay. Surf the three sites. Order from where it is the cheapest.
    I have ordered quite a few stuff from PSW. Awesome service. All of them good to be honest. Leslie is a little pricey!
    TFT-100 Test Kit.
    DX5+S Cleaner.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Don't forget Amazon and eBay. I just bought a new Century 2 speed pump for $115 on eBay. They normally run 3x that.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jul 2015
    TN
    11
    Ended up getting a B2977, goingit2salt, and a new cover removal tool from INYO for less than $400. They tried to sell me a motor with a timer built on, it was $100 more. Me being a master electrician, I have my timers already set up. So saved $100
    Looking forward to getting things together, deep cleaning filter and doing the chemicals the TFP way.
    SWG and controller
