Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Pool pump advise
    Feb 2015
    Chandler AZ
    933
    Pool pump advise
    Trying to help my daughter decide how to proceed with replacing/fixing her seized pool pump.
    Current pump:
    Wet end resembles a MaxFlo (looking at the strainer cover)(looks original to pool)
    Motor is a Northstar HP1.5 SF1.6 (a rebuild that came with the house when she bought it 1 year ago)
    Pool 13,000 gallon w/ attached spill over spa
    4 returns, waterfall, slide, suction side cleaner, 1 skimmer (main drain plumbed through skimmer housing)
    This pump filters and powers the entire system, except for the spa jets which are on a separate pump.
    Hayward sand filter - it's either an S210S or S244S (with a slide valve)
    Jandy heater w/ bypass valve
    I do understand the pros/cons of single speed, 2 speed and VS equipment - and the price differences. I believe my options are as follows...
    1 - Replace only the motor with same HP and SF (including new shaft seal)
    2 - Install new 2 speed pump
    3- Install new VS pump
    Location - Queen Creek, AZ
    Electric rate tops out at just under $0.14/kWh (summer peak)
    Pump run times have been 8 hours summer, 4 hours winter (will be working on reducing these)
    Attempting to get her to embrace the TFP method (but only part way there - )
    What I'm asking for is suggestions for the 3 options listed, given her electric rates. And if the present wet end is a MaxFlo, is the Northstar motor an appropriate replacement.
    Thanks in advance!
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Pool pump advise
    Between 1 & 2 there is the option of just replacing the motor with a two speed motor and using the same wet end. Sometimes it can be a bit cheaper than a new pump plus no plumbing changes.
    Mark
    Feb 2015
    Chandler AZ
    933
    Thanks Mark!
    I didn't even think of that. Would the 2 speed have to be rated the same as the existing motor (when new is running on high speed)?
    Also, there is only one timer in the sub-panel - with space for another. Would I have to add a second timer to allow the motor to automatically work on both speeds?
    Any specific motor recommendations?
    Yes, I'd rather not have to do any plumbing as there is little to no room on the suction side between the Jandy valve and pump inlet. I really dislike her entire equipment pad layout - no room to do much of anything. My pool set up is so much cleaner.
    Gene
    Jun 2011
    Long Beach, CA
    2,790
    Which timer do you have now? I have an Intermatic T10604R which has the T104M and T106M switches. The T106M is to switch the speeds while the T104M is the power switch.
    There are other ways to control the speed switching but this is a simple way to get the motor to switch speeds on a set schedule.
    Feb 2015
    Chandler AZ
    933
    Thanks for the reply Ping!
    I think it's a T104M as it is DPST running a single speed motor. I will have her or the SIL look when they get home from work.
    So I guess I would need the T106M in the blank slot to be able to automatically switch speeds???? The panel looks like the T40000R.
    And wire it up as follows:
    Mechanical Timing Controls For Two-Speed Pump Applications (Basic Wiring Information)
    Gene
    mas985's Avatar
    Pleasanton, CA
    11,741
    To get the correct motor, I would need to know which MaxFlo wet end you have. Is there any number located on the body such as SP2315x20?
    Mark
    Feb 2015
    Chandler AZ
    933
    I will try to post that info after they get home and I can ask or get pics sent to me.
    If it helps, the present Northstar motor is a SP1615-Z-1-BNSC --- part number 7-193233-U2 --- frame Y56J
    Gene
    mas985's Avatar
    Pleasanton, CA
    11,741
    The only issue with the old motor is they may not have sized it properly so I just wanted to make sure.
    Mark
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also make sure she has 240VAC going the pump as the single speeds can be wired either 120 or 240V where most / all of the 2 speed and variable speed motors require 240VAC
    Feb 2015
    Chandler AZ
    933
    Quote Originally Posted by mas985 View Post
    Ok, will get that info and post later.
    Quote Originally Posted by Isaac-1 View Post
    Yes, most definitely 240VAC.
    Gene
    Feb 2015
    Chandler AZ
    933
    The sub-panel is an Intermatic T40404R - it has a single T104M timer, so there is space to pop in a T106M timer to control the hi-low speed
    Instead of whats listed above, the sand filter is actually model S311SXV
    Attached is a pic of the wet end placard. Unfortunately, I can't make out a number.... In case it helps, here's the number from the strainer lid: # SP 3000-D
    Attachment 45167
    Gene
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In general the only time you need to switch a pump to high speed is to backwash or manually vacuum assuming there are no water features.
    Feb 2015
    Chandler AZ
    933
    Thanks Ike
    She has a suction side "The Pool Cleaner" 2 wheel, a waterfall and a slide - all powered by that pump. I guess the suction side cleaner may need high speed. The waterfall and slide could easily be switched to high during use if needed.
    The T106M timer is about $70 locally - and will automate switching from low to high for the cleaner (if needed).
    I'm leaning toward the 2 speed motor only option which Mark suggested. Hoping he chimes in sometime tomorrow with a motor suggestion.
    Gene
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Sounds like a plan, but I would think a simple double pole switch for hi / low speed setting would be more convenient than the timer, although I can see the set and forget appeal of the timer for a suction side cleaner.
    Feb 2015
    Chandler AZ
    933
    The set and forget would be best for them. Both work long hours and have a 3 y/o and a 9 month old to "entertain".
    It was hard enough for me to get them to test regularly. I finally got that point across.
    And they have also been using liquid bleach for almost a year now. Can't convince them to buy a TF-100 and my wife nixed giving them one as a Christmas gift.
    Oh well, at least my pool sparkles because of TFP!
    Gene
    mas985's Avatar
    Pleasanton, CA
    11,741
    If the motor is not working at all, one option is to remove the motor from the wet end, which you would have to do anyway, and look for a part# on the impeller. This would also tell you if you need any other parts besides the motor or if it isn't worth it to salvage the wet end.
    Otherwise, you could just go with a full rated 1.5 HP two speed motor but I suspect that motor is going to be too large for that wet end. It will still work ok, but would probably cost a little more than necessary.
    Mark
    Feb 2015
    Chandler AZ
    933
    With the already known mismatch of parts (motor and wet end) there is no telling what impeller might be in there. I will hopefully have time this afternoon to swing by and pull the motor. And I'll get some close-up pics of the wet end.
    If it comes down to replacing the entire pump, what would be a good 2 speed option given the other equipment listed?
    Thanks!
    Gene
    mas985's Avatar
    Pleasanton, CA
    11,741
    The maxflo XL is a really good efficient pump so I would not hesitate going with that. It comes in both a two speed and VS version.
    Mark
    Feb 2015
    Chandler AZ
    933
    Do you think the 1.5 HP version is appropriate for the other equipment?
    Gene
  20. Back To Top    #20
    mas985's Avatar
    Pleasanton, CA
    11,741
    As long as the pump does not run the spa or any other features the 1 HP should be more than enough.
    Mark
