Thread: Heatpump recommendations
    Oct 2007
    Parkland, FL
    752
    As with the other thread I posted on Salt water generators, I'm helping my friend that moved in down the street find a heat pump. From researching it looks like the gulfstream HI-125 would be a good fit. Thats the florida model with 5 year parts and labor warranty. I've also seen the RHEEM heat pumps 6350 I think would be a good fit for 2675 installed. The RHEEM doesn't have as nice a warranty, but is probably 500 dollars cheaper installed over the Gulfstream. The pool is a simple approx 10K gallon no spa pool. Would this be a good fit?
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Re: Heatpump recommendations
    I ordered the Hayward HP50HA heat pump this week. It is a fairly new model but all the reviews I found were favorable.
    Hayward Heat Pump HP50HA | Hayward HP50HA
    rajung's Avatar
    Mar 2015
    Iowa
    185
    I have the HE-125 and have had only one problem, the fan started to make very loud noise after the first year.
    Customer service was great.The problem was the rivets that hold the fan paddles to the main shaft area.Although impossible to see or even wiggle the paddles, just enough to resonate a terrible loud noise when running.
    They knew right away what the issue was and sent a replacement within days.Very happy with them.I also bought the cover for it for winters here.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
    Oct 2007
    Parkland, FL
    752
    Gulfsteam you can control with phone I believe. Rheem I get a little higher btu. Can get same warranty for a little extra.
    I had a Hayward for 10 years or so. Broke at least 5 time
    Quote Originally Posted by pooldv View Post
    DFW, TX
    24,484
    Quote Originally Posted by robl45 View Post
    Dang it!
    Oct 2007
    Parkland, FL
    752
    Dang it!
    The picture of yours is different style so hopefully you have better luck.
