Thread: PetersonPool
    Feb 2016
    Gilbert, AZ
    10
    PetersonPool
    Very happy to have found TFP resource. First time pool owner as of last summer. Just getting started with the season after a 80% drain the other day to deal with very high CYA. Hoping to have a much nicer pool experience this year.
    Also testing my sig shows up correctly for future posting.
    Thanks for this great resource!
    Rob
    ~11,200 gallon in-ground, built ??, pebble tec, hayward 1hp single speed pump on timer, hayward 3025 cartridge filter, TF-100 test kit
    Jun 2014
    15,008
    Re: PetersonPool
    Hi Rob. Sig looks good. The fact that you already knew you had to drain to lower CYA means you've been reading - . Welcome to TFP, and let us know if you need anything else.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: PetersonPool
    Welcome to TFP! So far so good! Here's to a great summer.
    Here are a couple of my favorite pages in case you missed them.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Re: PetersonPool
    HI! I see your siggy! Well done.
    What are you testing your water with?
    Kim
    Casey's Avatar
    SW PA
    10,423
    Re: PetersonPool
    Welcome.
