Thread: How do i turn my pump to waste to vacuum all the stuff off bottom.
    Mar 2013
    Yucaipa CA
    87
    I am slamming my pool and it has a lot of winter debris in the bottom. I scooped up the large stuff and after the shock is done want to vacuum the bottom but not clog my DE filter. I have a Pentair DE filter with a slide back flush valve. Is there a way to send the water to waste without flushing it backward through the filter?
    skeeter
    47 yr old(1977) 18,000gal Kidney shaped 38ft long plaster Pool with built-in Spa, Pentair Intelliflo VS3050 Pump, Pentair 48sf DE filter, Raypack RP2100 gas heater. HTH 5-way test kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: How do i turn my pump to waste to vacuum all the stuff off bottom.
    Just from the description of your plumbing I would say no. You would need a waste outlet somewhere between the pump and filter to do what you want to do, or replace the slide valve with a multiport valve. If you post a photo of your equipment pad we may see another possibility.
    Love TFP? Become a
    TFP Supporter!
    Mar 2013
    Yucaipa CA
    87
    From the looks of it i will have to add in a tee and a valve to do the waste. If i backwash doesnt that just reroute to the inside of the grids and that would not be good, correct?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Correct, That would be a mess. You would want to tee (with diverter) somewhere between the pump and the filter.
    Factory Warranty Station for:
