You did it!!! SWEET!
We are here to hold your hand as needed or to just cheer you along to a clear pool!
Kim
Kim
Yes. You have to pass all three tests at the same time. No CC, no Loss, and clear water. And clear applies after brushing! It's very possible to pass the first two tests and still have small patches of algae on the tile grout. You need to make sure it's all gone before you let up on the bleach. Do it right once and maintain adequate FC and you may never have to SLAM again. I've gone about 6 years without any cloudy or green water.I got up this morning and tested my pH and it was about 7.3 in my estimation, so I went ahead and added the chlorine to start the SLAM test. That being said, my FC level was the same as last night, so I seem to have passed the OCLT test. The water looks much better than before the two refills, of course, but I wouldn't call it a "sparkling pool."
Just took my first reading after beginning the SLAM (waited a bit more than an hour), and FC is at 16.5, yay! I hadn't thought about raising it to 20 (that makes PERFECT sense, thank you, CowboyCasey), so will do that adjustment.
Here's my thought; please chime in if I'm not thinking clearly.......I'll do the SLAM today.......clean the filter, brush the pool, etc......if I get up in the morning, and I've passed the OCLT test and don't have any combined chlorine, but pool is not completely clear, will I continue the slam?? Not sure I'm perfectly objective on what the definition will be of "clear" at this point. Thanks thanks thanks.
I will post my next FC result. It's great to have all of you here!
It is never too early to do an OCLT. Just take the reading after sunset and 30 min or so after your last chlorine addition to make sure it is well mixed. SWG off, if applicable. Be as precise as possible with sample size, hold the bottle vertically for best drop formation for both tests and try to be consistent from test to test.
Yes, I have a severe clear pool, passed the OCLT, and no cc!!!
Calcium hardness can be raised with calcium chloride or calcium chloride dihydrate. They are available in some areas as Peladow, Dowflake, Tetra Flake, or Tetra 94, often sold as a deicer by hardware stores, and some big box stores, in colder climates. Pool stores will carry either calcium chloride or calcium chloride dihydrate under a variety of names, including Hardness Plus, Balance Pak 300, Calcium Hardness Increaser, etc. Calcium products should be spread across the surface of the deep end of the pool.
