Results 1 to 16 of 16
Thread: Question after the fact
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    Was reading through the threads and see where ya'll say you fill up the "basket" part of the pump with water and turn on the pump and it starts running?
    We had to run water in the basket part for over an hour to get water coming out into the basket by itself. What were we doing wrong? We had all the plugs in and turned the mulitport to filter. Any thoughts?
    TIA
    NW Arkansas
    17,300 IG Gunite pool approx 16 yrs old (here when we bought the house in 2004)
    1.5 HP pump (rebuilt in '06)
    TA60 Tagelus Sand filter (sand replaced in '05)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Question after the fact
    Check to see if you have an air release valve at the top of the filter, this allows you to "bleed" out the air from the filter. That should improve the flow. Do you feel water coming out of the return(s)?
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    Yes we have the air release valve. We would open it and have water and air coming out.
    Mostly just air coming out of the returns. Maybe it's just normal to have so much air but you guys make it sound so quick and easy.
    NW Arkansas
    11,969
    Does the air come out first (from the air release valve) and then water? If so, that's normal.
    When you say air from the returns, you mean millions of tiny air bubbles?
    It sounds like you are sucking air some where, on the "suction side" of the filter. You do have the lid on the strainer pump basket on tight, correct? Make sure all your connections are tightened securely. Did you use teflon tape when making connections? Do you have any clamps that the screws need tightening?
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    No, my DH thinks the pump will overheat if we run it without it having water in the basket. It can be full and we put the lid on and then the pump sucks the water out so he takes the lid off again and runs it with a hose in the basket
    until it finally starts staying full....after an hour or so.
    I'm thinking that's the problem but try telling a man? haha
    NW Arkansas
    Feb 2008
    Denton, TX
    5,061
    So, you've checked to make sure that nothing is blocking your skimmers or any other plumbing that pulls water from the pool to the pump?
    Make sure water is in the strainer basket at the pump with the lid on securely. Power up the pump. Set multiport to "filter". Open air relief to purge air from system. Leave it open until there is just water coming out and then close the air relief valve.
    If at this point you lose prime again, try switching off the skimmers one at a time to see if things improve. You may even try switching the skimmers off entirely and just opening the bottom drain as your only source. Do all this in an attempt to see if you can isolate the location of the problem.
    30,403
    How far above the swimming pool water level is your pump?
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    It's below the swimming pool level...probably 18"
    NW Arkansas
    30,403
    If your pump is below the water level in the pool, the pump strainer basket should always be full of water...I am confused.
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    It is full of water now but they drained the pipes last fall.
    You're not the only one that's confused. Thank goodness we finally got it to work but I was just wondering how come it took so long. I think now I know
    NW Arkansas
    Quote Originally Posted by Torsie
    ...We had all the plugs in and turned the mulitport to filter. Any thoughts?
    I think this was overlooked in other replies... pump cannot suck water if the lines are blocked!!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    hmmm I guess I didn't say all those little plugs that screw into the pump and filter?
    That's the plugs I meant.
    NW Arkansas
    11,969
    I think now I know
    Well, are you gonna tell us?
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    haha oh sorry, I think it's because DH wouldn't leave the lid on the basket to the pump and he kept closing the little thingy for the air to come out on the top of the filter.
    Does that sound like a good reason?
    NW Arkansas
    11,969
    Um, yah.
    Feb 2008
    Denton, TX
    5,061
    This can make a difference!
