Rheem/Raypak M407 LoNox no power help!
Feb 15, 2016
2
Corona
We bought the new heater 2 weeks ago. We've successfully heated the spa to 100 degrees in a matter of minutes.
Last night we decided to heat the pool. The water is 61 degrees and set to heat to 80. After 2 hours we received an error code indicating the fan locked out. We turned it off for 20 minutes and started it back up. This morning I went out and the toggle switch was still set to on but the LCD has nothing on it. I turned it on and off and still no read out. I turned the breaker off and back on and still no power. I checked the board and connections and it's all in tact still. Please help! I have no idea what to do next. Thanks so much!!
