Thread: Rheem/Raypak M407 LoNox no power help!
    Feb 2016
    Corona
    2
    We bought the new heater 2 weeks ago. We've successfully heated the spa to 100 degrees in a matter of minutes.
    Last night we decided to heat the pool. The water is 61 degrees and set to heat to 80. After 2 hours we received an error code indicating the fan locked out. We turned it off for 20 minutes and started it back up. This morning I went out and the toggle switch was still set to on but the LCD has nothing on it. I turned it on and off and still no read out. I turned the breaker off and back on and still no power. I checked the board and connections and it's all in tact still. Please help! I have no idea what to do next. Thanks so much!!
    In ground pool and spa recently remodeled.
    Rheem/Raypak heater M407 LoNox - purchased 2016
    Pentax intellispeed pump - purchased 2016
    Pool is 38k gallons
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Rheem/Raypak M407 LoNox no power help!
    First, it's new and under warranty so call and get it looked at. I suspect the display LCD has crapped out. I've seen it before.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
