Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Yellow spots
    Feb 2016
    Plano
    20
    Yellow spots
    Hi all, i am new to this forum and novice in maintaining the pool. I fired my pool guy after i found out that he was charging me for the visits he never made during winter.
    So here is the problem. I see these yellow spots in one area as if something is leaking from the plaster. Do you know what this is?
    Swg - 15000 - plaster
    Just took the readings
    Fcl 3.5
    Ecl3.5
    Ph 7.6
    Alk 77
    Ch 360
    Cya 73
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Yellow spots
    Welcome to TFP!!
    Yellow, or more orangish - like rust?
    What are you using to get the test numbers? Results like 77 & 73 seem very specific.
    Support the site
    Feb 2016
    Plano
    20
    Re: Yellow spots
    Thank you!!
    Yes like rust. Can not upload pics here.
    I bought lamotte coloriq digital machine.
    15000 gallon with spa, plaster, hayward ctg filter, advantageman 2hp motor, bleach, poolvac XL
    May 2014
    Franklin, NC
    9,187
    Re: Yellow spots
    It very well could be rust from the shell of the pool if the plaster/gunite is beginning to break down. Or it could be rust from something that fell in the pool and sat in that spot and rusted..
    Photos would really help. You can't upload them using Tapatalk, but can from a computer.
    As to the Lamott ColorQ members here have reported that they tend to loose accuracy with age as well as a limitation of only registering a FC level up to 10. Above 10 it just reads "High". With a CYA of 73 (we call it 80) your FC target level should be 9 (unless you have a SWCG), which is close to the limits of your meter.
    For this reason we are generally reticent to trust their results. We recomed everyone have their own accurate drop based test kit like the TF100. With that you can regularly compare readings and see if your ColorQ is beginning to "drift" off accuracy.
    Support the site
    Feb 2016
    Plano
    20
    Re: Yellow spots
    Feb 2016
    Plano
    20
    Re: Yellow spots
    SWCG is shut off due to winter. Should i manually start it or add bleach?
    May 2014
    Franklin, NC
    9,187
    Re: Yellow spots
    Quote Originally Posted by Nayabsaiyed View Post
    The SWCG will not produce when the water is cold, so you need to manually chlorinate.
    Those photos do appear to be rust to me.
    Support the site
    Feb 2016
    Plano
    20
    Re: Yellow spots
    Ok thanks. Were you able to see the pics? What do you think?
    Aug 2014
    Northern IL
    4,615
    Re: Yellow spots
    They look like rust. For now, you can remove them with some vitamin C tablets in a sock and scrub away. Keep an eye on your FC and add liquid chlorine/bleach as needed. As for the underlying cause, there are others better equipped to answer that.
    Feb 2016
    Plano
    20
    Re: Yellow spots
    Thank you!!
    Quote Originally Posted by MarianParoo View Post
    Feb 2016
    Plano
    20
    Re: Yellow spots
    I was referring to this recommendations - Pool School - Recommended Levels
    According to this it states the FC should be 3-7. What am i missing?
    Quote Originally Posted by tim5055 View Post
    May 2014
    Franklin, NC
    9,187
    Re: Yellow spots
    You are missing CYA/Stabilizer. Our FC recommendations are all based on the CYA of the pool. You can't just look at that one chart.
    Try these three articles to explain it:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Here is an example of a ColorQ post: ColorQ vs TF100
    Support the site
    Feb 2016
    Plano
    20
    Re: Yellow spots
    Thank you for all your replies.
    I just went to the pool store to test the water. Here is what they are suggesting. Attached image. Do I really need to do the PHOSFree treatment? Or should i do the vitamin c tablet treatment?
    Dec 2015
    arlington, tx
    100
    Re: Yellow spots
    as an alternative pool chemical test kit, i have been using taylor's K-2006C kit and have liked it very much.
    May 2014
    Franklin, NC
    9,187
    Re: Yellow spots
    No, following our methods PHOSFree is not generally recommended.
    Quote Originally Posted by Marcion333 View Post
    You are correct, the K-2006C is very similar to the TF-100. They both use Taylor reagents. It is just that the TF-100 is more suited to a residential pool owner and a TFP follower as it contains more of the reagents we generally use and less (or none) of the ones we seldom if ever use. But, folks need to be careful comparing prices because the K-2006 comes in sizes, designated by a letter. The basic K-2006 has .75oz bottles, you need to get the K-2006-C to get the larger bottles that you want. Even then it is a little short on the reagent & powder for the FAS/DPD test.
    Support the site
    Aug 2014
    Northern IL
    4,615
    Re: Yellow spots
    I think you are missing this: Pool School - Chlorine / CYA Chart
    Do you have a salt (SWG) system?
    Feb 2016
    Plano
    20
    Re: Yellow spots
    Yes it is salt system but chlorinator is off due to cold temperatures.
    Aug 2014
    Northern IL
    4,615
    Re: Yellow spots
    Then, assuming your CYA is 80.....????? Your FC should target at 9 with a minimum of 6. You need to treat it like a non-SWG pool.
    Oh, and you can still do the vitamin C in a sock method on those spots.
    Feb 2016
    Plano
    20
    Re: Yellow spots
    Thank you so much. I am going to add bleach tonight.
  20. Back To Top    #20
    Aug 2014
    Northern IL
    4,615
    Re: Yellow spots
    Great! Let us know when you try the Vitamin C tabs on those spots.
