Thread: Pool Maintenace
    Feb 2016
    Montreal
    1
    Pool Maintenace
    Hi
    It has been several months since I have cleaned my pool, planned doing it myself
    Just done with the draining part of it and gave a start with the cleaning but then not able to complete it as it is not easy to completely remove these algae from the floor. I guess it needs the help of certain equipment's to completely remove them off. Hope some profesional in town can help me doing this.
    My friend has suggested me ferrari pools.
    I have also heard about certain other professionals like Paradise pools, Albatrosspools, etc. Have u guys called any of them ?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: Pool Maintenace
    Hi,
    We here a TFP care of our own pools and maintain them ourselves.
    If you have algae, then the chlorine and likely also the CYA levels are not being kept at proper levels.
    My recommendation is to read these articles. They will be of help in understand the cause of the algae and how to remove it.
    Pool School - SLAM - Shock Level And Maintain
    Divin Dave,
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,406
    Re: Pool Maintenace
    HI! We can help you take care of your own pool for much cheaper and easier than any pool service.
    The first thing you need to do is a get a good test kit. With that our pool maintenance will be a breeze! Look in my siggy below to find the link to the test kit we use and love.
    Kim
    Jun 2014
    14,980
    Re: Pool Maintenace
    Hello and welcome to TFP. As Divin Dave mentioned, we are a Do-it-Yourself crowd as much as possible, especially when taking care of the water chemistry. Once you have the proper test kit, you will know exactly what the water readings are and can treat the water with normal, everyday household chemicals like bleach, soda wash, baking soda, etc. The links to pages Dave gave you are fantastic. Most importantly though, you'll need to right test kit, and I believe in Canada you can only get the Taylor K-2006. Check with some of your fellow Canadians for a source, but that's the one we would recommend. Good luck, and let us know if you have any more questions.
    Aug 2014
    Northern IL
    4,615
    Re: Pool Maintenace
    Is the pool still drained?
