Thread: Pump not filling
    Oct 2012
    Maricopa, Arizona
    109
    Pump not filling
    Trying to figure out why the pump basket isn't filling. The only time it does is when I pour some water in so it can prime. I've checked to make sure the impaler isn't clogged by sticking a screwdriver in to feel if it turns, which it does. The pool vacuum seems to be working. Seems to prime fine once I pour the water in but once I shut it down the water starts going down to maybe to where it's only a 1/3 fill.
    Inground SWP, 10,000 gals., Pebble Sheen, Hayward pump cartridge filter, Aqua Rite SWG, year installed 2011
    Jun 2014
    15,189
    Re: Pump not filling
    Generally, when the pump basket loses water after shut-down it's because there is an air leak somewhere - usually on the suction side. Have you tried everything on this page yet? Pool School - Suction Side Air Leaks.
    Also, what type of filter do you have (sand?) Sometimes, a bad multiport valve/gasket can influence your system seal.
    Oct 2012
    Maricopa, Arizona
    109
    No, didn't know about that page, thanks. I will check it out along with the suggestions on what to do. Couldn't do anything about it today, had to work. I'll get on it tomorrow. To answer your question: I use cartridge filters.
    Oct 2012
    Maricopa, Arizona
    109
    Update: Pump seems to be working fine now. Cleaned the O ring off with the hose, had the hose run water into the pump for a few minutes, turned everything back on and ran the pump. Water filled up, pump ran fine. Turned the pump off. No air leak. No water loss. Pump is staying fill. Thanks for the help.
    Jun 2014
    15,189
