Thread: newbie from Florida - New pool owner
    Feb 2016
    kissimmee florida
    20
    Hello everyone,
    New home and pool owner official yesterday!
    Hoping everyone can help me understand high pressure low flow on D.E filter. This site by far has more logical/acceptable answers then the others I went on.
    So I signed up. First forum I have ever been a part of.
    Hopefully I can talk to the pool gods and get some much needed help.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,510
    Re: newbie from Florida - New pool owner
    HI! Welcome to another FL person!
    I bet we can help you figure out anything you do not understand or know about your pool.
    I think you should post a thread in "just getting started" Ask the question about your filter. Once you get where you understand that move on to the next thing you want help on. Do it one question at a time BUT in the same thread.
    Make sure to name the thread something that stand out so we KNOW it is you. "Need help in Kissimme" would be a good one.
    Kim
    30,421
    Welcome to the forum. We'll need to know how low is the flow and how high is the psi? Probably just needs cleaning but we need to get a baseline.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Welcome to TFP! Congrats on the new pool!
    Start here, Pool School - Read This Before You Post
    Amd here, Pool School - ABCs of Pool Water Chemistry
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,503
    I suspect that you might have a misunderstanding as to what your filter "Pressure" gage is telling you. Try thinking of it as a "Resistance to flow" gage instead. As filters get dirty it gets harder and harder for the water to get through and you see this by an increase in the Pressure or Resistance to flow gage. If you think of it this way, it is obvious that as the pressure goes up, the flow will go down.
    As Dave says the most likely cause is that the filter has collected enough gunk that it needs to be cleaned.
    You can clean your DE filter two ways. You can do a backwash, which runs water through your filter backwards to the normal flow and flushes about 80% of the gunk. Or, you can open the filter and remove and thoroughly clean the DE grids.
    Since knowing what the "clean" pressure is supposed to be is very important, I suggest you do a full cleaning. It is relativity easy to do, but, depending on your previous pool experience, it might make sense to have a pool service come out and show you how it is done. From then on you can just do it yourself.
