Results 1 to 9 of 9
Thread: Please help balance
    Aug 2015
    Dallas, TX
    8
    Please help balance
    Hi, We had a new pool so we are new to all this. The PB was maintaining the pool for the two months and now are doing it ourselves. Here is my test results from TF-100 kit.
    FC= 1ppm
    Total Cl = 1 (no combined chlorine)
    PH=8.2
    TA = 60
    CH = 325 ppm
    Salt = 3200 (from salt cell); I tested 4600 ppm = not sure if I made a mistake testing
    CYA = close to zero (not sure if we got this right but when the jar is close to full filled, the black dot just about disappears. I had got the same (NO) CYA a month ago when the PB was testing it but he said the CYA was 30.)
    Temperature of water = 55F
    The PB has provided Muriatic Acid and some trichlor.
    18x34 freeform gunite (14k gal) play pool 3.6-5-4, stonescape, TN flagstone coping, AK boulder weeping waterfall 12x12; 450sf sundeck; Hayward 2-speed motor; Hayward DE 60Sf; Acquarite Tcel 15 (salt cell); 400,000 BTU propane heater; 1/2 HP booster with polaris 280; 1.5 HP blower for spa; savi solH (2); Savi mini melody (1)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: Please help balance
    Congrats on the new pool!
    TA, CH and salt are fine.
    It is very important to keep PH between 7.2 and 7.8, especially in a new pool. It will take about a year for your plaster to fully cure and your PH to settle down. Test it often and add muriatic acid to lower it 7.3-7.5.
    The trichlor will keep adding CYA to your pool, stop using it when your CYA gets to 50ppm. More here, Pool School - How to Chlorinate Your Pool
    Keep your FC above the minimum level at all times for your CYA, Chlorine CYA Chart, this will keep your pool sanitized and algae free.
    Start here in Pool School - ABCs of Pool Water Chemistry
    Aug 2014
    Northern IL
    4,615
    Excellent reply. That's a lot to take in. Let us know if you need any clarifications on specific issues.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    You can probably use a dozen trichlor pucks to get CYA close to where you want to be. They're also acidic, which will help stabilize the pH with the fresh plaster curing.
    My suggestion: plug your numbers into poolmath and dose it to get pH to 7.5, and then put a couple pucks in a floater. Right now, the water is cold enough that algae is not a terrible worry, but you do want to keep the FC up just to be safe. The SWG probably isn't generating much if the water is so cold.
    Aug 2015
    Dallas, TX
    8
    Thanks to all. Since I already had dichlor from PB, I used it according to the calculator. Not sure how much CYA it would add. When should I test next to see whether my additions worked, in a few days? Do I need to add additional acid for pH as shown below. It seems that the dichlor should lower the pH as well. See attached result from calculator.
    (unable to add the image showing the results from the calculator but it shows adding 13 oz muriatic acid)
    DFW, TX
    24,517
    Every 10 ppm Free Chlorine (FC) added by Trichlor also adds 6ppm Cyanuric Acid (CYA).
    Every 10 ppm FC added by Dichlor also adds 9 ppm CYA.
    Yes, you need to lower the PH. It is very important to keep PH between 7.2 and 7.8, especially in a new pool.
    Aug 2015
    Dallas, TX
    8
    A week later,
    Free Cl = 6 ppm
    CC=none or 1 drop
    Calcium H = 300 ppm
    Total Alkanity = 60
    pH = 7.9-8.
    CYA = none (am I measuring it wrong)
    Salt = 3400 (salt cell says 3200)
    Temperature of water = 64F
    According to pool calculator, I need to add Muriatic acid and liquid stabilizer for CYA? Wouldn't Muriatic acid increase the free chlorine as well? If my CYA measurement is wrong, would I mess things up by adding stabilizer.
    Jun 2014
    15,298
    Hello Dallas! Before we go too far, let's re-cap the CYA testing. Here's my little tutorial:
    Proper lighting is important for the CYA test. You want to test for CYA outside on a sunny day, but keep the skinny view tube in the shade. Taylor recommends standing in the sun with your back to the sun and the view tube in the shade of your body. Use the mixing bottle to combine/mix the required amounts of pool water and R-0013 reagent, let sit for 30 seconds, then mix again. Then, while holding the skinny tube with the black dot at waist level, begin squirting the mixed solution into the skinny tube. Watch the black dot until it completely disappears. Once it disappears, record the CYA reading. After the first test, you can pour the mixed solution from the skinny view tube back to the mixing bottle, shake, and do the same test a second, third, or fourth time to instill consistency in your technique, become more comfortable with the testing, and validate the CYA reading.
    Also, your pH is high, so try to bring that down right away to about 7.5-7.6. Acid does not increase FC (chlorine). Only bleach or your SWG does that. Let us know if you are still having trouble doing the CYA test.
    If the black dot "never" disappears, it means you either have no stabilizer in the water (CYA), or perhaps just added it today. Remember, if you add the granular stabilizer, it takes about a week to show-up on tests. The liquid, although more costly, shows-up in just a few hours or the next day. Be cautious though. We don't want to over-shoot your ideal CYA goal.
    DFW, TX
    24,517
    Here is a handy page from Pool School about chemicals, what they are, what they do and how to use them, Pool School - Recommended Pool Chemicals
