Results 1 to 7 of 7
Thread: Returns on same wall as skimmer on IG Pool
    Central Connecticut
    159
    Does anyone have experience with having the returns on the same side of the pool as the skimmer? If so, any issues?
    I am having my pool plumbing redone. The are recommending having the 2 returns on same side of skimmer and the eyes pointed down at a 45 deg angle. Right now I have 2 returns but one on the skimmer side and one opposite. I also have 2 returns in the stairs. Not sure they do much to help circulation.
    Rich
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Returns on same wall as skimmer on IG Pool
    Mine are setup that way. Periodically I redirect the jets, but most of the time they aim toward the walls rather than down.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Central Connecticut
    159
    Does it seem like you get good water flow back to the skimmer ?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    The goal for optimum skimming is to create a circular flow pattern, either clockwise or counterclockwise. Usually one way will work better than the other depending on the wind. All returns should be pointed in the same direction to create the circular flow.
    Central Connecticut
    159
    What is the best way to create a circular pattern in a rectangular pool?
    Rich
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Experiment with different directions. I put ping pong balls in and watch their pattern and adjust.
    DFW, TX
    24,450
    Good idea on the ping pong balls. The theory is the same for rectangular or curved wall pools.
