Thread: Should I add less DE?
    Jun 2014
    Glendora, CA
    61
    I recently added DE powder after cleaning the filters. The filter had some holes which the powder went into the pool causing the base surface to be cloudy.
    Anyways, I just bought brand new filters but don't know if I should cut back on the DE recommended powder since I recently pour some.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Should I add less DE?
    When you replaced the grids, didn't the DE leave with the old grids?
    Mark
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Assuming the extra DE is in the pool and not the filter, I would add the full amount and just know that the filters will clog up quicker than usual because you'll vacuum up the stuff in the pool.
    The reason is that DE screens are pretty sensitive. If you undercharge it, parts of the filter will not be coated, and any sand or grit or twigs that you vacuum up could get embedded in the screen when they aren't coated. Imagine a bunch of kitchen sponges covering a screen made of chicken wire. That's a DE filter under a microscope. The DE coats the screens and seals up the openings and the water gets filtered through the pores. If you're missing a patch, the water will go through that instead of the coating because the holes are bigger.
