Thread: sizing of SWG
    Feb 2016
    Lafayette
    11
    sizing of SWG
    Quote Originally Posted by cowboycasey View Post
    Not sure if you are wanting to stay with a NAME brand SWG, but I love my curcupool SWG.. I have only had it for 1 year but it has worked great... I did have an error on it and I called the company and they next day aired a complete new system to me...
    Just so you know, they always have a special and almost always a free upgrade
    at 1100 or so and a free upgrade to RJ60 3.2 pounds per day at 100% CircuPool® RJ-45 Salt Pool System
    http://www.discountsaltpool.com/Circ...tor-Manual.pdf
    Mine is the SJ series but it only does 25%, 50%, 75%, and 100% but I still like it but I control the amount of chlorine by pump runtime
    at 800 for the SJ55 and a free upgrade at 2.35 pounds a day CircuPool® SJ-40 Salt Pool System
    http://www.circupool.com/downloads/sj_20150516.pdf
    and a 7 year prorated warranty even when you install it..
    First Year - No charge for parts.
    Second Year - No charge for parts.
    Third Year - Parts supplied at 50% of normal price.
    Fourth Year - Parts supplied at 60% of normal price.
    Fifth Year - Parts supplied at 70% of normal price.
    Sixth Year - Parts supplied at 80% of normal price.
    Seventh Year - Parts supplied at 90% of normal price.
    How are these sized. I was trying to figure out pool size rating for each.
    Jun 2011
    Long Beach, CA
    2,778
    Re: sizing of SWG
    Each manufacture has a gallon rating for their cells and it is somewhat equal but not exact either.
    This link has the amount of chlorine is generated in 24 hours with the output at 100% for most cells, Full Market Comparison of Salt Water Chlorine Generators for Swimming Pools.
    A larger sized cell will last longer as compared to a smaller cell and the larger cell will need less run time to produce the amount of chlorine needed for the pool.
    I recommend to get a cell that is 2 or more times larger than the actual gallon size of the pool.
