Thread: Freeze protection shutting off
    steve57765's Avatar
    Aug 2015
    Lexington NC
    47
    I've kept my pool open as cold winter continues. With these long spells of below freezing temps I noticed the pump would shut off, for about ten minutes, then back on for 30 -40 minutes then off 10 minutes, etc.
    is this normal? It's fine with me, saves some power and still keeps pipes from freezing.
    when it only gets below freezing for short times, couple hours at night then back up during the day, like most of the winter here in NC I shut power off completely so freeze protection doesn't even turn on, but this cold spell is suppose to last several days
    Thanks, Steve
    Steve- 19K IG PebbleTec (sandy beach color pebble) final plaster/pebble August 2015
    Jandy pro cartridge filter
    Jandy pro series Plus HP PHPF pump w/waterfall
    Polaris 360 pressure cleaner- TF-100 w/SpeedStir
    50ppm Borates
    ps0303's Avatar
    Jul 2011
    FL
    3,688
    Re: Freeze protection shutting off
    Do you have an automation system on the pool?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Unless it gets extremely cold (arctic temperature range) your water will not freeze in the 10 minute time things are off.
    steve57765's Avatar
    Aug 2015
    Lexington NC
    47
    No automation Paul - it's just the yellowish colored box with timer and temputure dial for freeze temp
    Im not worried that pump shutting off for brief periods will cause problems, in fact I think it's a good thing as reduces power usage. This is my first winter with pool and just wondering if these freeze protection units are built to shut off that way
    50ppm Borates
