Thread: Liquidator installed In Full sun
    Dec 2015
    Newington, Connecticut
    113
    Has anyone had any known issues with installing the liquidator in full sun. The instructions say not to install in full sun, however all my pool equipment is in full sun on the south side of my home. I guess I could put a piece of plywood over it to shade the tank. Don't know if extending the tubing would effect the operation of the system.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    JoyfulNoise's Avatar
    May 2015
    13,230
    Re: Liquidator installed In Full sun
    No hands-on experience with a Liquidator but I can say for sure that heat & light (UV) exposure will cause bleach to degrade faster and lose its effectiveness. So the installation warning is probably based on keeping it cooler by not having it in direct sunlight.
    Matt
    Aug 2014
    Northern IL
    4,615
    Chlorine's effective strength/concentration will be reduced with exposure to heat/sun. I'm not sure about tubing, but shading sounds like a plan.
    30,426
    Cha-ching!
