Thread: Freeze protection on pump
    steve57765's Avatar
    Aug 2015
    Lexington NC
    47
    I've kept my pool open as cold winter continues. With these long spells of below freezing temps I noticed the pump would shut off, for about ten minutes, then back on for 30 -40 minutes then off 10 minutes, etc.
    is this normal? It's fine with me, saves some power and still keeps pipes from freezing.
    when it only gets below freezing for short times, couple hours at night then back up during the day, like most of the winter here in NC I shut power off completely so freeze protection doesn't even turn on, but this cold spell is suppose to last several days
    Thanks, Steve
    Steve- 19K IG PebbleTec (sandy beach color pebble) final plaster/pebble August 2015
    Jandy pro cartridge filter
    Jandy pro series Plus HP PHPF pump w/waterfall
    Polaris 360 pressure cleaner- TF-100 w/SpeedStir
    50ppm Borates
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: Freeze protection on pump
    It's normal. Mine does the same thing.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    steve57765's Avatar
    Aug 2015
    Lexington NC
    47
    Maybe the current going through the box heats up the thermostat?
    50ppm Borates
