Results 1 to 9 of 9
Thread: Particles In Water
    Oct 2015
    Burleson, Texas
    178
    Particles In Water
    Should a pool with a DE filter look like this? I always see things floating when I turn the light on. The PB said he back washed the filter when they did the acid was a couple weeks ago. I figured with a DE filter there wouldn't be anything in the water.
    21,000 gallons, Salt, IG Gunite, Plaster Finish, Free From, Pentair FNS DE cartridge filter, Pentair Intelliflo-VS pump, Intellichlor IC-40, 2 port fountains, bubbler in tanning deck, Dolphin M400, TF-100, K-1766, Speed Stir
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    Re: Particles In Water
    I really do not think ANY water will be without some fine particles in it no matter how good the filter. How does your water look in the sun?
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Agree, I have stuff floating in my water most of the time. There is usually some wind blowing something into the pool. At night with the light on is most visible. It comes and goes depending on wind and how much dust is in the air. Lawn mowers really stir it up. Water looks nice and clear. That is the downside of TFPC, nice clear water lets you see everything.
    Oct 2015
    Burleson, Texas
    178
    During the day it's fine. Clearest pool I've ever seen haha. I was just thinking that if a DE filter is supposed to get the finer materials there wouldn't be much to see in the water.
    Jul 2012
    Tallahassee, FL
    30,559
    LOL just think of how much I owould see with my sand filter! THAT is why I do not have a light. Oh and I live in Florida and the bugs love light at night so..........
    Kim
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have the same thing happening, and here is my take on it. If im right or not, I dont know, but it seems logical to me.
    I think I may be at least partically right, because I dont see the floaties all year long.
    The filter will only filter out what gets passed through it. Depending on how long each day you run your pump, stuff which floats in may settle on the bottom of the pool. As the pump then comes on later, the stuff on the bottom gets disturbed and floats into the water column and becomes visible in front of the light at night. So, really, the cleaner the bottom is, the less of the floaties will be visible.
    Durning winter I have lots of floaties too because I dont run my robot very much. During spring and summer, I run my robot a lot and filter longer and I dont see the floaties that I do in the winter time.
    Divin Dave,
    wjr75's Avatar
    Jun 2013
    IL
    836
    I use to get that when I had regular plaster. Now with the Pebble Sheen re-finish I don't see it at night.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Oct 2015
    Burleson, Texas
    178
    The robot does stir up some things when it's ran.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Floaters. Everybody's got some.
    My experience: frequent brushing helps eliminate them. They're like aquatic dust -- they stick to surfaces and don't just settle to the floor like they should. Brushing gets them into circulation so the filter can grab 'em. Brush 2-3X/ week for a month and you'll see fewer floaters in the light.
    I also seem to have fewer since I switched to cellulose from DE.
