Results 1 to 12 of 12
Thread: Need some help on repainting a pool
    Feb 2016
    Lafayette
    11
    So 3 years ago we hired some one to paint our pool. They did a terrible job. Now it is worn out again. I need to paint would love to replaster it but no money for that. So what steps need to be taken to repaint it.
    Aug 2014
    Shallotte, NC
    693
    Re: Need some help on repainting a pool
    Probably a good cleaning and removal of loose paint is all that is required. Don't expect paint, in a pool, to last more than 3 years. It just won't.
    Feb 2016
    Lafayette
    11
    It never really looked good from the beginning he was supposed to prime and paint and he just painted. Then said the paint had primer mixed. So I guess when it will be warmer for couple of days I will drain it and pressure wash it. Didn't know if I need to wash with muratic acid.
    Aug 2014
    Shallotte, NC
    693
    Quote Originally Posted by scottburlette View Post
    Sent from my SAMSUNG-SM-G928A using Tapatalk
    This MAY have been what he used..... http://www.homedepot.com/catalog/pdf...b48c2c9792.pdf
    It does give a little prep information....
    Feb 2016
    Lafayette
    11
    He used some Sherman Williams paint.
    Apr 2013
    Sacramento, CA
    2,769
    Just realize you will be repainting in 2 to 3 years no matter what prep work you do.
    Feb 2016
    Lafayette
    11
    Yea I hate this option but 700 for paint and 9000 to guinite the pool. I think I will go the paint route
    Wheels007's Avatar
    Aug 2015
    Winchester VA
    42
    Hey Scott,
    Make sure you find out what kind of paint was used previously. I'll post how to test when I get home.
    Duck's Swimming Pool Service & Repair
    Winchester, Virginia
    Wheels007's Avatar
    Aug 2015
    Winchester VA
    42
    From A Ramuc PDF. I highly recommend their paint. Also make sure you prep the surface correctly for proper adhesion. Let us know what type of paint you have and we can go from there.
    To determine the type of coating you may have on your pool or slides please follow
    the procedure outlined below:
     Apply denatured alcohol to a clean cloth and rub onto surface. If the paint sof-
    tens then the coating is probably a water-based acrylic paint.
     Apply Xylene or Xylol to a clean cloth and rub onto surface. If the paint softens,
    put a small amount of Xylene or Xylol on your finger and rub the surface in cir-
    cles. If it softens and “strings” the paint is probably a chlorinated rubber based
    paint. If the coating softens but does NOT string, then it is probably a synthetic
    rubber. If nothing happens to the paint coating when you rub the surface with
    the Xylene on the cloth, then the paint is most likely an epoxy, or a gel coat.
    NOTE:
    For testing a white surface use a dark colored cloth
    For testing a colored surface use a white cloth.
    If there is any doubt as to the type of paint on the surface, take a sample to your
    local paint store or dealer to send to RAMUC (800-745-6756) for definitive analysis
    Feb 2016
    Lafayette
    11
    I know it was a 2 part paint it had a harder mixed with it I will call Sherman Williams and ask pool guy went out of business
    Wheels007's Avatar
    Aug 2015
    Winchester VA
    42
    It was likely a 2 part epoxy paint. I can not be sure though. Can you post some pics of the damage? Epoxy should last longer than 3 years but has to be applied correctly.
    http://www.lincolnaquatics.com/Documents/260.PDF
    Check out this application guide. IF it is epoxy (probably is) this is your procedure.
    Feb 2016
    Lafayette
    11
    It's just faded real bad he did a terrible job on it he missed spots and came back touched it up said he could part it while filled then we got in the pool and your feet would stick to it. Now I believe it is worn out to bad because I couldn't keep it clean at all during the last couple of months of summer. Pool is like a swamp right now. I will never say what I paid but I paid good money for this pool to be painted and I glad he is out of business. I should have sued him but I didn't want the headache and about 6 months after he did it he lost everything due to the bad work he was doing. Came with great references when we decided to use him.
