Results 1 to 7 of 7
Thread: Vinyl pool liner
    Apr 2012
    Yakima, WA
    58
    Vinyl pool liner
    Hi everyone, haven't posted for a while. I am hoping you can put my mind at ease. We had a lot of snow here and the snow melted and brought the level of my closed pool up past the skimmer. I put my little pump in to bring the level down below the skimmer. It's a very slow pump and I planned to turn it off later, but guess what, I forgot!
    This morning as I left for work I saw that it was pumped way down, there is about 3 or 4 inches of water still in the shallow end. I am filling it back up. Is this going to mess up my liner? It's about 45 right now, it will be about 35 tonight, It probably got down to 35 or so last night.
    Thanks as always, Dave
    Dave
    Yakima, WA (the Palm Springs of Washington!)
    IG kidney 14k gal, 33 x 18
    vinyl liner
    200 lb Sand filter
    3/4 HP pump
    First time pool owner
    30,421
    Re: Vinyl pool liner
    If you don't see any wrinkles now, it is probably just fine.
    If you see them, they will be hard to remove
    Apr 2012
    Yakima, WA
    58
    Thanks Dave, haven't really looked yet.
    Dave
    vinyl liner
    200 lb Sand filter
    3/4 HP pump
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,510
    I am hopeful that with some water in it you should be fine! Fingers crossed for you!
    Kim
    Apr 2012
    Yakima, WA
    58
    Thank you Kim, pools full now and it looks good!
    Dave
    vinyl liner
    200 lb Sand filter
    3/4 HP pump
    Jul 2012
    Tallahassee, FL
    30,510
    I have a timer just for my pool for things like this. "There is NO way it has already been 15 mins! I just sat down!" Alls well that ends well!
    Kim
    Casey's Avatar
    SW PA
    10,444
    Thank God you found it before draining the shallow end!
