Thread: Chlorine way too high!
    May 2015
    Gulfport, MS
    109
    I just went out to check the chlorine level in the pool and I stopped at 52 drops but the water in my tf100 was still dark pink. I have a swg but its set to off. It has been off for close to a month. Why is their more chlorine than last time I tested a few weeks ago?
    12X20x54" Saltwater 8000 semi-inground, Waterway 1.5hp 2speed 22" Pump Sand Filter, Hayward Goldline Aquatrol HP SWG, TF100
    Aug 2014
    Shallotte, NC
    693
    Re: Chlorine way too high!
    Given the scenario, as stated
    1) we had an original testing error, or
    2) the SWG hasn't really been off, or
    3) somebody has added chlorine of some sort, or
    4) we have a more recent testing error.
    A magnitude of 52 drops makes me suspect #2 or #4. Are you sure you were titrating with the correct bottle? And is there any way the SWG has gone rogue?
    Were you using the 10 ml or 25 ml test?
    May 2015
    Gulfport, MS
    109
    10ml test. How would i diagnose the swg being bad?
    May 2015
    Gulfport, MS
    109
    Nevermind im an idiot. I was using the reagent not the fas dpd bottle. chlorine level is fine.
    Aug 2014
    Shallotte, NC
    693
    Quote Originally Posted by Straight6tt View Post
    ........I was using the reagent not the fas dpd bottle.
    Everybody has done that at least once.......
