Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: DFW Pool Build
    DFW Pool Build
    We're finally super close to pulling the trigger and getting under contract.
    All I'm waiting for is a breakdown on the exact equipment we are getting but here is what I have so far. Anything stand out to anyone? I need to get it in writing but the builder has mentioned possibly doing an even swap from the booster pump and cleaner to a robot. Question I have is whether or not I'll need the booster pump anyways to be able to run the water feature.
    How many jets should be put into an 8x8 spa?
    99' perimeter
    472 sq. ft.
    2 skimmers and 5 returns
    8' x 8' raised spa with spillway
    large tanning ledge with 2 bubblers
    oklahoma flagstone
    rock salt finish deck
    retaining walls
    400k BTU heater
    Silencer blower
    DE 60ft2 filter
    Intelliflow variable speed pump
    Booster pump
    Polaris 280 cleaner
    2 LED lights in pool, 1 LED light in spa
    Smart phone controls and automation
    Raised beam water feature
    Standard tile
    Grey plaster
    Enough with the boring stuff, on to the pics.
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Re: DFW Pool Build
    What a nice design! I LOVE the way you tucked a table in!!
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,492
    Re: DFW Pool Build
    The booster pump is what makes the Polaris cleaner work. I agree with ditching both and going with a robot cleaner.
    How do plan to chlorinate the pool? Now would be the time to decide it you want a Saltwater pool, which I highly recommend.
    The EasyTouch automation and Intelliflow VS pump work very well together.
    JoyfulNoise's Avatar
    May 2015
    13,199
    Re: DFW Pool Build
    You don't need a booster pump to run water features. My suggestion would be that you put all of the water feature plumbing on a separate loop so that the main pool pump simply drives the pool filtering and the spa. If the spa plumbing is designed correctly (and not too far from the equipment pad) air boosters are not necessary. Many PBs who have been around a long time still use air boosters in their design even though they have been made obsolete by variable speed pumps. Or, they use air boosters because they don't design the plumbing properly. There's a lot written on TFP about air boosters but you may have a hard time convincing the PB they are not necessary. At the very least, you could do without it at first and then, if the spa jets just aren't powerful enough for you, you can add the air booster later.
    Back to the water features - the reason why you want them on a separate loop is because (A) you DON'T want to turn them all the time and (B) too many water features will overwhelm your pool pump and force you to run it at very high speeds just to get the flow you need. You can probably get away with the bubbler hooked up to the main pump but the scuppers (or sheer descents, whatever you want to call them) are a different matter. Open water features like scuppers and sheer descents are what your might call low-head discharge features. That is to say, those types of water features require high volume water flow but not necessarily high pressure. So in those types of features you want to use a waterfall type pump which is designed to operate at high flow but low head (low pressure). The bubbler needs higher pressure but not necessarily lots of water volume so that is why I say it can probably remain on the main loop.
    +1 for the SWG recommendation.
    And, as is my personal opinion and a soap box I am always ready to stand on, you should get yourself a dedicated vacuum line for manual vacuuming. Dedicated vacuum lines are often used in conjunction with suction-side cleaners BUT even if you don't use a suction cleaner, having the port available for hooking up a vacuum hose and doing some manual vacuuming is really convenient. You will hear a lot of hype about how, once you own a robot, you will never have to vacuum manually again. While that might be true in certain pool layouts, your layout has a sufficient enough complexity that a robot is not always going to get every nook and cranny. As well, if you have a period of high debris (like fall leaves or some such time), then any automatic cleaner, be it pressure cleaner, robot or suction cleaner, will get easily overwhelmed. A dedicated vacuum line is cheap and easy to add to a design BEFORE your pool is built. It is impossible to add it later and, at that point, your only option is to use the skimmer for hooking up a manual vacuum.
    And finally, I know it's just digital mock up BUT the last thing you ever want near your pool for landscaping is the Pampas grass (ornamental grass). It will mess your pool up. You want to keep the landscaping near you pool to things that have very slow growth, minimal flowering and definitely NOT deciduous. Otherwise, your pool will become the waste container for all the landscape debris that is generated each season....
    Matt
    Oct 2015
    DFW, TX
    176
    Re: DFW Pool Build
    Matt-- I've seen your note re: dedicated vacuum line in other threads and have made note of it to go over with my PB. Do you recommend doing that even if we already are doing a suction-side cleaner?
    May 2015
    13,199
    Re: DFW Pool Build
    Quote Originally Posted by darin.brown View Post
    If you already have a suction side cleaner in your build, then I would certainly add a dedicated vacuum port as opposed to hooking up to the skimmer. When you hook it up to the skimmer, you just make it so that you can only operate the suction cleaner or the skimmer, but not both. I believe there are adaptors out there that try to fix this problem by splitting the flow inside the skimmer so that you can have both going, but it's a kludge at best.
    If you have a suction-side cleaner in your build plan, then I would always recommend a separate, dedicated vacuum port to run it from that home-run's right back to the equipment pad and uses a Jandy style shut-off valve to control the flow. DO NOT allow the PB to put a dedicated vacuum line in series with the skimmer or else you'll get lousy suction flow.
    Matt
    Re: DFW Pool Build
    We signed paperwork a while back and once permits were done they got started once it dried out a little bit.
    Dig started on April 7, 2016
    My 2016 pool build, 13,250 gallons 14' 6" x 35' 6" 99' perimeter 472 sq. ft., IG gunite play pool with table, 8' x 8' spa with rolled neck and spillway, 400k BTU heater, Cartridge Filter, Intelliflow variable speed pump, Polaris 280 and booster, raised beam water feature with 2 port fountains, Jandy PS4 with iAqualink automation, Sanitized with Bleach, TF-100 Test Kit with Speed Stir.
    Re: DFW Pool Build
    Plumbing and Steel started and finished April 9, 2016. One funny thing is that we caught one of the plumbers putting my propane tank back in the grill since theirs ran out. I will never forget his smile and insistence that it was OK.
    Couple days later the pool builder brought me a nice refilled tank and apologized for it.
    Here are the pics.
    It's kind of hard to see it in this photo but they left steel out of the corner since it's the way the bench was shown on the drawings apparently from a bug in the software. The builder and I caught it and the steel was continued in the corner by the spillway for the spa bench to wrap all the way around.
    Re: DFW Pool Build
    And after passing inspection, gunite was shot April 13, 2016. I had to water for a few days before the rains really hit DFW this weekend and we now have water up to the floor level of the table area.
    Tucker020's Avatar
    Mar 2016
    McGregor, Texas
    85
    Re: DFW Pool Build
    Wow! Love the design. At least with all the rain you don't have to worry about keeping the shell wet for the curing stage. This rain is killing me. It's been 11 days with 0 progress. At the decking and electrical stage. I'm just ready to get my backyard put back together.
    amandahein3's Avatar
    Mar 2015
    rowlett, tx
    853
    Re: DFW Pool Build
    Woohoo another pool with a table! We love ours and spend all of our time around it!
    Looking great! When is the next step? Where in dfw are you? We are in rowlett
    Free form pool 90'3" prim, 14180 gallons. TF100 Kit In pool table with travertine top, 3sheer descents, Depth 3.5-5-4, Jandy 2HP pump, Inline Chlorinator, Wetedge Satin Matrix Antigua.
    Re: DFW Pool Build
    Electrical is happening today. Tile and coping guys are backed up with all the rain and I don't have a date for them yet.
    How did they attach your table top to the pedestal in your pool? Ours will be a 42" square of 2" leuders and I'm nervous that if it ever lets loose someone could lose a toe in the pool.
    Re: DFW Pool Build
    Awesome surprise when I came home today. Tile and coping guys were here with the electrical crew.
    Feb 2016
    Houston
    323
    Re: DFW Pool Build
    Love your spa corner spillover. Can't wait to see photos later today of your tile and coping.
    My pool thread. IG 31' x 20', 3.5'/4.5'/6', 8' spa, 4T moss rock WF/WW w/jumping rock, 7' x 11' sunshelf 3 bubblers, travertine coping, spray deck, Hayward equip: SwimClear 525 Cartridge Filter, H400 natural gas heater, Tristar Dual Speed EE pump 2HP, Tristar EE pump 1.5HP for water features, blower 2HP, Prologic P/S 8 w/aqua pod remote, Aqua Rite T-15 Salt System, Tigershark QC robot, networked Colorlogic LEDs 2 pool 1 spa.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: DFW Pool Build
    Happy Friday!
    Re: DFW Pool Build
    Here's a shot of it with a bunch of rain water.
    Electrical guys wrapped up last Friday and the tile and coping guys got started but aren't the fastest crew. They got the water line tile set in the pool and that was it Friday. Saturday was wasted since one of the guys was having a baby.
    Here's the table top
    And here's where they wrapped up last night. Hopefully they can finish all the coping today and get the spa tile work done.
    Oct 2015
    North Richland Hills, Texas
    191
    Re: DFW Pool Build
    Love your build! We're doing the same corner staggered spill off on the corner of our spa. Looking good!
    My Journey - 16x38 In-Ground gunite (14k gallons - 3.5-5-4) w/ Crystal Stones Smooth Tropical Isle - OK Flagstone coping - 693sqft spray deck decking - Jandy 580sqft Cartridge Filter - 2hp Jandy E Pump (VS) - Contracted Pool 4/22/16 - TF-100 Test Kit - 7x7 raised spa w/ rolled tile edge - Jandy nicheless LED lights (5) - Aqua Pure Salt Kit - Dolphin s300 robot - Zodiac NG JXI 400k BTU for spa - iAqualink PS8 w/ 4 relays - Jandy LED bubbler
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,467
    Re: DFW Pool Build
    LOL on them not being the fastest workers BUT they are "artist with a big saw" so be glad they are taking their time to do a good job.
    Kim
    Re: DFW Pool Build
    Quote Originally Posted by kimkats View Post
    Kim
    Understand completely, they did an awesome job. Just made the comment since our last pool the tile and coping was all done in one day.
    Yesterday was a busy day with a nice surprise when we got home.
    Tile and coping was finished.
    The spa came out fantastic. These pics were after dusk so I'll try and get a better pic tonight when I get home.
  20. Back To Top    #20
    Re: DFW Pool Build
    Big surprise was that the decking was all formed up.
    There's some tweaks that need made since the forming crew screwed up but it should all be fixed today. Hoping for a pour first thing in the morning tomorrow.
