Results 1 to 10 of 10
Thread: Cover Free
    Mar 2015
    South Texas
    411
    Cover Free
    There are mixed reviews for this product online and even on this website so I thought that I would share my experience here.
    I live in a very warm climate and it is almost Spring here. Daytime temps have been approaching 80 degrees with lows at night in the 60's. My water temp has fluctuated between 60 and 64 degrees. So, in order to speed the process I bought some Cover Free at Leslie's as it was on sale.
    So after using it for 2 weeks now I can safely say that it simply does not work. My water temp has stayed between 60 and 64 and it definitely has not slowed evaporation either. Now, that in itself is not the worst part! This stuff burns up my Chlorine, big time! I have gone from adding half a gallon of liquid chlorine twice a week to having to add it every other day. All other factors have been relatively constant (temps, no bather load, etc.).
    So all I can say is don't bother with this stuff, not only does it not work, it costs you more in the long run due to excess Chlorine consumption.
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Cover Free
    It's a decent idea in theory, these chemical cover products that purport to reduce evaporation rates from the pool by coating the top surface of the pool water with a chemical that prevents evaporation. However, if there is any wind or turbulence on the surface of the water, the chemical is simply mixed around in the top layer of the pool, resulting in poor performance, preventing the product from working as intended.
    I'm sure that in a laboratory setting with no water turbulence, these products perform well. In a real pool with circulation and wind... not so much. I have not tried the products myself as just thinking about this in a "thought experiment" didn't give me much optimism in their effectiveness.
    Isolated Spa - 345 Gallons
    Jun 2014
    15,103
    Re: Cover Free
    I never really paid much attention to this product until your post, after which I obtained the MSDS to see what was actually in this item. Unfortunately, the MSDS doesn't really say much. I couldn't find anything on-line in my few minutes of searching to confirm the specific ingredients/chemicals. I'm always skeptical about things like that - seem too good to be true.
    30,419
    Re: Cover Free
    Over and over, we get reports of failure for these products to be really effective. It DOES sound good......it just doesn't work well.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Re: Cover Free
    There are a few limited conditions at our pool n which it "works" but perhaps not in a meaningful way...I post this only for others reading.
    So lets say its October and you live in Michigan where it might be 40 degrees at night and 70 during the day and your a crazy woman who heats your pool to 86 for your morning swims and you don't have or want a pool cover due to footprint of pool area. You like to swim at 7 am and no, it will not be anywhere near 70 degrees yet You don't really want your gas bill to be more than $300 that month.
    The water is still in the am after the drop to 40 degrees. Faint wafts of steam coming off the pool, where the water tension is not broken. Then you dive in, breaking the water tension. Suddenly there is literally a "fog" rising from your dive point.
    Up until the point of diving, the CoverFree was a good idea in this case. Subsequent to the point of swimming, it will be an ok idea again until you run the robot and disturb the water surface. On a windy day, its a bad idea again. But the nature of the product is to form a one molecule thick layer that is lighter than water. So it will "reform" when the wind stops.
    With this kind of temp differential, you can actually see the difference upon application. But its use is limited...and if you're willing to use a cover, then the cover wins hands down
    Maybe this fall or early spring I should try a bucket test and do a 2-day bucket test to see if there's truly a 70% evaporation differential. My husband is convinced it makes a difference on the heating bill in shoulder seasons but we can't exactly run a control
    But I will say that in my experience, I use an average of 2-3 ppm FC per day when the pool is heated, dosing to 7, and I've not noticed any differential in FC use based on whether the CoverFree has worn off or not. I will pay attention this season and see if I notice a difference!
    Its exciting to talk/think about such a test, because at the moment, its 8 degrees here Maybe I should put a drop in my coffee and go stand on my deck to see what happens
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Oct 2015
    Wind Gap, PA
    89
    Re: Cover Free
    Any updates on this? I found some left by the previous owner and I was really wondering if it works...
    19,400 gallon IG ,vinyl, Hayward 1hp Single Speed, Wall-pak Cartridge Filter, Pool filled from well, TF-100 test kit
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Re: Cover Free
    Hi Spoolin. I haven done any of the above tests because I fear they'd be skewed
    I've installed a Rockys Roller to cover at night now that ve removed te winter dome. I do use the cover free during the day if temps are cooler and I can see steam, but since I cover at night I'm not sure if it just sticks to the cover and is dragged off.
    Night temps are dropping to 50s again, so it may be a few weeks til I'm leaving it open at night to do a test, but. Will try to remember to do so
    Honestly, I. The mean time, just pick an early am when you can see steam risn from the pool and pour in a dose of the leftover. You will immediately see a reduction in the fog
    Helpful Links:
    Oct 2015
    Wind Gap, PA
    89
    Re: Cover Free
    Quote Originally Posted by Swampwoman View Post
    I was only looking into it to reduce evaporation because I fill off my well water which has metal in it.
    Guess I'll just keep filling as usual.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    419
    Re: Cover Free
    I believe this stuff is rubbing alcohol.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Oct 2015
    Wind Gap, PA
    89
    Re: Cover Free
    HAHA
