Results 1 to 8 of 8
Thread: Buying new above ground pool, recommendations?
    Feb 2016
    Citrus Heights
    4
    Getting ready to buy a new pool. I owned an Intex 16' for a year and want to upgrade larger with a deck. Local doughboy dealer has a 28' silver lake model in stock for $2,700 with pump, filter, ladder, liner. After reading around on the site I'm leaning to a salt water system and wanted some advice. Will the above pool be a good salt pool? What is a good swg for above ground pools? Would it be better to buy just a pool and liner and then buy pump, filter, swg separately? I haven't ordered anything and am open to suggestions on what set up would work best, we travel on long weekends frequently and that is why I'm leaning to swg. Thank you in advance for any advice.
    Casey's Avatar
    SW PA
    10,427
    Re: Buying new above ground pool, recommendations?
    Welcome. Doughboy pools are great pools. If you can get a 2speed pump and a large filter, that is the way to go. 2speed to cut down on electric cost. Largest filter you can afford to keep cleaning to a minimum. I prefer DE filter but others like sand and cartridge filters. I'll defer to someone else on recs for salt water generator. I don't own one n still dump chlorine every day or two.
    While you're nailing everything down on things needed, add a TF100 Test kit to your pool package. You can find the link in my signature.
    Feb 2016
    Citrus Heights
    4
    Thank you! I forgot to mention that I live in Sacramento CA if that helps.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Doughboy pools are great. My parents pool is 30 years old and the rails are just starting to get some rust. Not sure how the salt would effect one.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Feb 2016
    Citrus Heights
    4
    So I got some more information from the dealer. The pool comes with a 20mil liner and 1.5 hp hayward pump with large sand filter and ladder. They told me a salt water generator would void a warranty and that even if i upgraded to a resin pool that all of the hardware would rust. Any of you guys with the salt pools run into that problem? Could I get a can of clear coat and spray all of the hardware as I tighten everything down?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    That 1.5 HP single speed pump would be a killer with California electrical rates and may even be against state law. I think California has a law about max size for single speed pumps being 3/4 HP, but that may just apply to in ground pools. As to the large sand filter, large is relative we cant say much without knowing model, or actual size.
    Feb 2016
    Citrus Heights
    4
    Will the saltwater rust the metal top frame? Should I buy an all resin pool instead?
    Cigar2011's Avatar
    Jun 2014
    Shohola, PA
    5
    When I purchased my doughboy I was going to do saltwater then balked at the idea due to the warranty issue. I then found this post here on TFP
    So you want to add borates to your pool--Why and How
    I haven't done it yet but plan it this season. If you didn't buy the saltwater system this is atleast worth a read.
    Happy swimming
