Lookin' good! What's your plan for plaster?
So dv are you saying we don't need to purchase the salt test?
I feel like I should start buying the stuff needed today maintain the pool once complete. What all will be needed for a SWG pool? Thanks.
Sent from my XT1096 using Tapatalk
We are in Sonora, about 90 minutes from Lodi. Love it up here.I saw the trunk that had the 209 area code on it. Where are you in California? I have lots of family that lives in that part of Cali. My parents live in Woodbridge outside of Lodi and my wife's family is in Turlock and Los Banos.
Thanks for the tip on bleach, laundry room it is. Our pool shed will be wood, thinking of getting a TuffShed.It is a better to keep bleach in the laundry room or pantry, heat will reduce the strength over time. Once the pool is up and running you won't need to add bleach much. 121oz adds 4 ppm FC to my 20k pool. So, I add a jug before pool parties or each morning on big swim weekends to boost the FC a little. That way I don't have to mess with SWG time or percentage.
Muriatic acid is best kept outside, under a deck, behind a shed, somewhere shady. If your pool shed is wood or plastic that is OK, but it will outgas and rust anything metal that is nearby. Especially after it is opened.
Do you have a link to the calculator? Thanks!You said you don't know how many gallons, it might be a good idea to ask the builder or use one of the many volume calculators that are available and see if the estimated volume is inline with the SWG cell you are getting. I don't think I have ever seen a post about a cell that is to large but there are quite a few that were under sized leading to either having to add CL or at the least longer pump run times to keep the production at an acceptable level.
When it is time to fill if your water is metered taking a reading before and after the fill so you can get the real volume. I say real volume because the builders and online calculators use averaging, I was told by the builder my pool would be 15,500 gal not all that different than I got online, problem was the Baja shelf was not take into account, real volume came in at just over 12,000. If you are not metered you can time the fill and then do a bucket test. See how long it takes to fill a 5 gallon bucket with the hose you used to fill the pool and divide the pool fill time by the bucket time and multiply by 5 gallons. Knowing the true volume form the start can make chemical management much easier. No matter what the volume over time you will get a feel for how the pool will react to each addition.
