Results 1 to 12 of 12
Thread: I Have a Bonehead Electrical Question.
    Jun 2014
    Roseville, CA
    345
    I notice that my salt system has three wires going in: two black and one green for 240 VAC.
    Why no white common wire(s) like in 115 VAC?
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: I Have a Bonehead Electrical Question.
    White on a 120VAC circuit is the neutral. There is no neutral on a straight 240VAC circuit. Neutral is 120V from each of the lines on a 240V circuit, so it's only needed if you want both 120VAC and 240VAC in the same device.
    Jun 2014
    Roseville, CA
    345
    Where is the return path?
    My Ideal Specs:
    JoyfulNoise's Avatar
    May 2015
    13,262
    Well, assuming the installer/electrician did his job correctly, then in a 240V system you only need a neutral (white) wire if there is something in the box that requires a strict 120VAC power source.
    So perhaps the 240VAC wires attach to to a multi-tap transformer that supplies all of the necessary voltage levels for whatever is inside the box. Logic boards typically use 12VDC supplies (stepping down to 5V as needed) and the SWG normally needs a 24VDC power supply. AC-to-DC conversions can be done on board the control electronics for either the logic board or the cell power supply.
    Just a guess though unless you post a picture of the internal wiring layout.
    Matt
    Oct 2015
    Austin, TX
    83
    The two wires are 180 degrees out of phase. One pushes while the other pulls, and then the first one pulls while the other pushes.
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    Jun 2014
    Roseville, CA
    345
    Thanks for that. It now makes sense!
    I'm installing a dedicated timer for my salt system, since my water solar panels keep the pump running and I can't control my chlorine generation. Opening the box reminded me of this question I'd been wanting to ask.
    Thanks again to all.
    My Ideal Specs:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    I did the same thing, my SWG is on its own timer. Just make sure that the pump is always on when SWG will be on.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Is your timer a single pole or dual ?? If single it's only opening the circuit at the timer and both wires are still HOT. One is hot to the timer and the other wire is hot to the pump and back to the timer.
    If it's dual pole then it's breaking the circuit on both wires and both of the wires leading out of the timer and to the pump are dead.
    I'd still make sure the breaker is off in either case before working on anything.
    Solar Blanket, Well Water, Borax Added. 76
    Jun 2014
    Roseville, CA
    345
    Breaker will be off.
    The pump runs a lot for the water solar, and additionally I have the flow/no flow switch for the SWG in case I set something wrong.
    I'm going to redirect the power to the new switch, then back to the SWG. The line/power descriptions are very clear for 240VAC.
    My Ideal Specs:
    Jun 2014
    Roseville, CA
    345
    Another question regarding L1 and L2 in a 240 VAC circuit.
    Do all L1's have to be hooked to L1's, and all L2's have to be hooked to L2's?
    For example, I have the power from the source going to the SWG timer, then down to the SWG control box. Should all the connections be L1 to L1 to L1, and L2 to L2 to L2?
    My Ideal Specs:
    Dec 2014
    Riverside California
    482
    Quote Originally Posted by Chuckiechan View Post
    Makes no difference at all. AC connections are not polarity sensitive.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Jun 2014
    Roseville, CA
    345
    Got. Thanks for that!
    My Ideal Specs:
