Thread: Variable speed pump
    Jun 2014
    Glendora, CA
    61
    Variable speed pump
    Thinking of replacing my current pump (don't know the name since label is off) to a variable speed pump such as the "Hayward SP2302VSP". I mainly use the pool vacuum (The Pool Cleaner) and don't use the skimmer that much.
    Would a variable speed pump be ideal for my situation?
    TT
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Variable speed pump
    Please add your pool info to your signature, more here, Pool School - Read This Before You Post
    It depends on a few factors like do you have a heater, solar panels, SWG, water features. A VS pump will give you maximum control of water flow to achieve the correct flow rates and maximum energy efficiency. But, it might be overkill and a 2 speed pump might be just fine.
    Jun 2014
    Glendora, CA
    61
    No heater/solar. Just a 48 sq. ft DE filter.
    DFW, TX
    24,450
    I love my VS pump. I run it at 1100rpm for skimming, filtering and making chlorine with the SWG. My pump only uses 150 watts at 1100 rpm. A 1 or 1-1/2hp VS pump would be great for your set up. A two speed pump would also be good and it would be cheaper. A two speed pump on low moves half the water and uses a quarter of the electricity as it does on high speed. Run it on low most of the time for filtering and on high for faster skimming or vacuuming.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Without knowing your "situation" not sure how to evaluate the need or the value.
    Would be worth the time to jot down the specifics of your pool equipment and add them to your signature as outlined here - - > Pool School - Getting Started
    Once we know what you have we can try to give you informed guidance.
    Solar Blanket, Well Water, Borax Added. 68
