Thread: Considering purchasing used HP600 Heat Pump, please help
    kimdurg's Avatar
    May 2014
    North Canton, Ohio
    46
    I am considering purchasing a used HP600 Heat Pump. The only information I can find online is that parts are still available for purchase. (I guess that's a good thing).
    The gentleman believes it's rated at 81,000BTU and for a 19,200 gallon pool. It heated his 10,000 gallon pool (which he no longer has).
    I called Hayward, after being on hold for 20 mins, I hung up and emailed them. Their response was, we basically, we no longer make this unit.
    Sent: 02/10/2016 I am looking at purchasing a used HP600 heat pump. I can not find
    > anything online, except parts. I am trying to determine if this will
    > work with my pool. I have an in ground 16x32, approx 20,000 gallons
    > (3.5-8 feet). Also, if you have a link where I can find a manual?
    > Thanks
    Sorry, we only have some parts available for this
    unit only, because the unit is no longer made.
    Thank You,
    My concern is that my pool is approx 20,000 gallons (16x32 avg depth of 4.5), would this work for my pool?
    I'm in NorthEastern Ohio, I'm looking to extend my swim season (currently, I won't get in the water until the end of June), I keep a solar cover on the pool. The pool is in FULL SUN usually from 9:30ish until the sun sets. It previously had a solar heater on the roof of the house. I do not know how well it worked as they had to be taken down for a new roof before the pool was opened and not knowing how old they were, etc, I opted not to have them reinstalled.
    Thanks!
    20K gal; vinyl in-ground; 1.5HP Hayward pump; Hayward Sand Filter; Well water; K-2006.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Considering purchasing used HP600 Heat Pump, please help
    Im using some calculations I read on threads here.
    20,000 gal x 8.3 lbs = 166,000. If you go with rating of 81,000 BTU it would take 2 hrs to raise the temperature 1 degree F. It would probably be much longer depending on outside temperature, wind, ect. I'm not sure you will be able to extend season much, from reading threads here about heat pumps in our climate. Maybe somebody will correct me here. If you still have the solor panels you might think about combining them with the heater. Also, if you dont have extra 220V electric service to the pad you should figure the cost of that also.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    kimdurg's Avatar
    May 2014
    North Canton, Ohio
    46
    Thanks for the info
    Sep 2012
    Pittsburgh
    35
    I am getting rid of my heat pump and getting a gas heater". My heat pump needs repaired almost every season and does not work well when we have cool fall pa nights. At 60 degrees outside temp it is useless.
