Thread: iAqualink Help Needed
    Feb 2016
    Mandeville, LA
    2
    I have just installed the iAqualink System in my pool and have programmed everything. My problem is that I can't find a place in the system setup menu to change the light color. I have the Jandy LED Lights and they work fine turning on and off but how to I change the color?
    Thanks in advance for the help.
    Joe
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: iAqualink Help Needed
    You need to get onto the "WEB" tab at the top of your screen. Once connected, at the bottom of the screen, MENU, then SYSTEM SETUP, then COLOR LIGHTS. Then choose your light type. From there, i think you can get where you need to go.
    Factory Warranty Station for:
    Feb 2016
    Mandeville, LA
    2
    Thanks for the quick reply and the help. The system and the app is great but I can't seem to find any kind of user manual or tutorial for setting everything up. I am kind of winging it as I go.
    Thanks again!
    Jul 2015
    239
    I have fiber optics for my lighting system and had to map the color wheel to an auxilary relay. I believe the Jandy LEDs just require toggling their power within 3 seconds to switch colors.
    Edit: I think what Pool Clown said is true. Check out this manual here:
    http://www.jandy.com/~/media/zodiac/...h/h0305600.pdf
    And here:
    http://www.jandy.com/~/media/zodiac/...h/h0364200.pdf
    16,500 gallon IG Pool & Spa: Intelliflo VS pump, Pentair Triton II TR-100 sand filter, Teledyne Laars Lite2 propane heater
    Laminar Jets (2): Hayward Maxflow SP1600 1/2HP, Hayward Star Clear C500 cartridge filter
    Jandy iAqualink RS-8 Rev T, Hayward AquaRite AQR15, Dolphin Supreme M5, Taylor K-2006, Taylor K-1766
