Thread: Polaris 3900 Wheels slipping on plaster
    Feb 2016
    Kenner, la
    1
    I have a 12 year old pool that has a regular white plaster finish. My Polaris 3900 slips and gets stuck with the wheels turning on the steps, or up against the steps without climbing over them. I put new wheels on the Polaris, but no help. Sometimes it will just sit in one place until it reverses, then starts slipping again in another spot. Does anyone know how to get more traction against the plaster? Does anyone make "snow" tires for a Polaris??
    Thanks for your comments.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Polaris 3900 Wheels slipping on plaster
    Hey TLD,
    One of our Polaris owners will be along to help answer this better than I.
    Welcome to TFP, and enjoy your time in the forums.
    Essential Links:
    Jul 2015
    Central Valley CA
    1,107
    To some degree you can reduce the pressure to the tail with the set screw near the tail, that will increase the water pressure of the jets to the bag and by extension hold the unit down to the floor and walls. You want the tail to gently sweep back and forth if it is not moving back and forth you turned it down too much.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Oct 2015
    Katy/Texas
    411
    Mine has a movable nozzle on the back. If yours has one, perhaps you can point it in a different direction. Mine gets stuck occasionally but that is why the reverser is there.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
