Results 1 to 9 of 9
Thread: Hayward Lateral Replacement??
    Hayward s244t sand filter..
    Last season I had small bits of leaf material,etc that would not filter out thru the sand filter. I cleaned the filter twice with the method recommended here. Got lots of small bits to come out with the over flow,but still had bits returning to the pool at a rate that would clog my small filter on the Polaris 165 vacuum. I'm guessing the laterals may be cracked/broken allowing this to happen. Filter is 6 years old but has new multiport valve as of last year. Would lateral replacement cure this or possibly the whole lateral assembly with main tube also replaced???
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    Re: Hayward Lateral Replacement??
    If you're not getting sand back in the pool, then the laterals are probably fine. I would suspect a bad internal air relief screen.
    Support the site
    Quote Originally Posted by JamesW View Post
    Thanks James,,, can you explain to me about where/what the air relief screen is--thanks
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Make sure the pipe from laterals is perpendicular and not out of center and you add water slowly when changing sand. I have this plastic piece that holds it. You probably already know this just trying to help
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    That filter might not have an internal air relief. Are you getting sand in the pool?
    Support the site
    No sand in pool,just small bits leaf bits.... Couldn't find air relief on diagram of s244t...thanks!!
    Ok, I don't think that there is an air relief. If no sand in pool, I would suspect a bad multiport gasket or a bad seal between the standpipe and multiport.
    Support the site
    banditig's Avatar
    Sep 2015
    Ohio
    466
    If it's a bad gasket they leak outside or mine kept discharging water out of the backwash hose when put in filter mode. Just guessing but the top of the stand pipe needs to fit snug in the multi port. My first one was kinda disintegrated so I replaced it. Also, I make sure I have the maximum level of sand. There shouldn't be leaves passing through it
    The multiport gasket is a circle with multiple spokes. There are different ways for the water to leak depending on how the gasket might be damaged. It can be damaged in a way that allows water to bypass the filter without leaking to waste.
    Support the site
