Thread: Can high pH reading be attributed to high FC readings?
    Oct 2015
    Palm Harbor, Florida
    2
    Chlorine readings are above 6, and PH is 8+, are they related. SWG system, at 25%,
    water temp in 60.
    DaveS
    14,500 gallon fiberglass, SWG, solar heated w/ 2hp, QuikClean system
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Can high pH reading be attributed to high FC readings?
    Welcome to TFP!!
    Not really. You need to add acid to to get the pH down into range.
    Depending on the level of Stabilizer/CYA in the water 6 may be low, fine or high. Do you know what the CYA level is?
    Check out - Pool School - Recommended Levels
    Support the site
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    if FC was 10 or above yes.
    Dolphin E10 Cleaning Robot.
    Oct 2015
    2
    CYA is 80
    DaveS
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Rphdave View Post
    CYA is 80
    Great, 6 would be our recommended target FC for a SWG pool with 80 CYA.
    Support the site
