Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Electric line installation advice needed
    Laenini's Avatar
    Aug 2008
    Brooklyn Center, MN
    90
    Hi Everyone!
    After wanting one for many years, my husband and I finally purchased an above ground pool last August. Its a 24' round by 48" deep pool and included in the purchase price was a professional installation. Although the pool was barely up and running before it was time to close it down for the winter, we did use it enough to know that we are thrilled with our purchase!
    Spring has arrived, and we are getting ready to open the pool. Since we had such a short time to use the pool last year, we opted to hold off on installing the electric line until this spring (we used a heavy duty extension cord with a GFI attached to hook into our garage electric for the few weeks we ran the pool). But now its time to finish off the job right by having an electrician install a proper, dedicated line. The pool installers last year told us all we needed was a single outlet mounted on a post, and that sounded about right as we just had one plug from the pump going into the extension cord anyway. But now I am wondering if we could use more outlets? We have decided that we want to install a natural gas pool heater (we had somehow thought we could skip putting in a heater, we were dead wrong on that one up here in Minnesota!) So the igniter on the heater will need an outlet too, right? Then it has occurred to me that some sort of timer for the whole system could be pretty handy, so should we should plan another outlet to manage something like that (any advice on what to get for a timer while we are at it?) Are there other needs you more experienced pool owners can think of that might make us wish we had even more plug-ins available for pool equipment? I can just see us having the electrician out over and over again as we dream up more and more accessories to add to our set up. I would love to think ahead enough to avoid that.
    I am grateful for any advice, thanks all!
    Leanne
    Leanne
    Pool: 24' round by 48" deep AGP
    Waterway 1HP-2 speed pump, H100 Heater, sand filter, skimmer, using BBB (love it!)
    Hot tub: 2008 CalSpas, 8x8, 8 seats, 60+ jets, ozonator
    3 step bromine sanitation
    Re: Electric line installation advice needed
    Welcome to TFP!
    You have several choices. The most expensive and the most flexible is to run a line large enough to power an electrical sub-panel out by the pool with perhaps 50 amps. That way you can add additional circuits as they occur to you with minimal extra effort. The nice thing is that this option isn't really all that much more expensive, and you will have lots of future flexibility.
    30,415
    Electrical outlets and circuits are always in short supply...no matter the location.
    I'm on the same page as Jason......cost out the 50 amp panel and put it in if the price isn't absurd.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Ditto above advice...
    we have one elec pole by the pool and it has 2 plug recepticle.
    Heaters vary, ours is wired somehow, but it doesn't get plugged in, because right now the other plug is open. That part is a mystery to me!
    Laenini's Avatar
    Aug 2008
    Brooklyn Center, MN
    90
    Thanks everyone. I think I will have a few electricians out to bid a 50 amp panel as suggested.
    Leanne
    Jun 2008
    Carrollton, GA
    88
    Hi,
    I have an 18X33 above ground pool and I have two 30 amp breakers dedicated to the pool. We are only using one of them so far. There are six outlets with a GFCI and 2 flood lights wired directly with an on/off switch. Two of the outlets are on a post on the pool deck to plug in stereos and computers.
    My electrician was my brother (who is an electrical engineer). He provided the wire. The breakers were already in my
    breaker box and were extra breakers. The only cost to me was renting a ditch witch to dig a trench, the outlets, and the floodlights. He also ran a water line from the house to the pool for me since I had rented the ditch witch.
    I do not know what the cost would have been if I had hired an electrician. Anyway, I would suggest putting in extra outlets for future use.
    Susan
    18x33 AGP, BAQUAPURE 200 lb sandfilter, 2 1/2hp Workhorse pump (2 speed)
    Laenini you my be in for a big surprise when you have a electrician over. You might be required to get a electiral permit. We are going through the same with our new pool. The 2008 NEC codes are a pain in the butt and expensive.
    **Beginning full restoration soon**
    IG 25,000 Gallon 18' x 36' x 8' max depth, built ~1972
    Tagelus TA-60 sand filter
    Plaster, needs resurfacing, considering Ultraguard
    Plan to convert to SWG
    Jun 2007
    New Jersey
    653
    If you are digging a trench, you might consider a separate conduit for low-voltage. I did a 40 amp 220V sub-panel (for an inground pool) and a separate 1" low-voltage conduit. I eventually ran 2 Cat-5,(phone and internet), 1 Co-ax,(TV) and two 16ga speaker leads (audio) through the conduit once I figured out what I wanted. The pull was a family affair, one kid and myself feeding wires, one greasing and one pulling.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Quote Originally Posted by ywait42
    This is correct...my electrical work had to be done by an electrician licensed with the city...unfortunately getting one to come out and do such a small job was a nightmare. No one would call me back...finally I found someone and when I went to apply for my permit, their license had expired. I had to beg for a temporary one time job permit in order for them to finish it work they had already started. Please Please Please, check with your local municipality before you do any work...it will save you headaches in the end! It will make getting permits and passing inspections that much easier.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Jul 2007
    New Hudson, MI
    48
    I would recommend asking for bids on two options: the sub-panel option ( perhaps 60A would be better, especially of your pump requires a dedicated 20A circuit rather than a 15A circuit), as well as simply running (2) circuits (15A or 20A, but you may NEED 20A for your pump depending on its motor size). The second option is your minimum if you want to run anything besides the pump itself, like you said the heater controls. The heater controls consume very little current and that circuit could be shared with a few general purpose outlets as well.
    Good luck!
    Scott
    27'x52" AG Vogue Impact, Waterway Cyclone 200 cartridge filter, Waterway pump w/2 HP 2-sp motor, 8mil solar cover, Raypak 206 nat gas heater, Pool Rover Jr.
    Apr 2009
    Raleigh, NC
    55
    Here's a picture of my neat little receptical post, installed myself. Enjoy
    93mastercraft - Aqua Leader Reflexion 21' round 54" high above ground pool. This is not a $399.00 Pool! Wedding cake steps, Haywood 1.5 pump/sand filter. If I'd thought taking care of a pool was this easy, I'd owned one a long time ago!
    93mastercraft your pool looks like a resin pool can you tell me if and how you put in your bonding grid?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    here is a link to my electrical post....I also have a resin pool and just figured out how to bond it...you'll see a pic where I was able to pull away/bend the resin upright and attach a copper bonding block to the screws holding the steel wall together....attacher #8 copper wire to pool pump and done You'll also see my homemade aerator in action...got the design idea from this forum...as I need to lower my TA
    enjoy
    http://s702.photobucket.com/albums/ww30/dmanb2b/
    Jun 2008
    North Carolina
    38
    Hey dman. Thanks for the pics. What kind of tubing is that attached to your pump and filter?
    Round 24' AGP
    13,500 gallons of cold water
    Sand filter
    BBB
    North Carolina
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    your very welcome...it's flexible pvc (aka tigerflex...glues just like pvc pipe)...I have a inground pump and filter, so I decided to hard plumb it all...the unions will give me the flexibility to add my SWG and solar panel, after I build the deck....I feel ywait's pain...pool permit $100 (included elect permit), Deck permit $150...since I had no room in my breaker box, I needed a 200 amp uprade...the deck...let's not go there...the darn pool is the cheapest part of this whole thing.
    May 2009
    Jasper, TN
    249
    Quote Originally Posted by 93mastercraft
    The power connection/post has to be at least 5ft from the pool according to the NEC, I think.
    Yours looks a bit too close
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    May 2009
    Jasper, TN
    249
    Quote Originally Posted by Durk
    So you ran phone, internet and TV to your pool location?
    Your new pool heater doesn't need electricity. Save your money.
    25,000 gallon....36x18....inground vinyl....hayward 1 1/2 h.p. pump.....pentair de filter
    Aug 2008
    Conway SC
    102
    I know this is slightly *cough* *cough* not to code, But all my Electrical lines (Pool Feed, Line to my Flower bed 100' from house, line to my Light posts) were all done by the Irrigation company. Darn only took them probably 30 minutes to do all of it and they did it for FREE..
    Ok.. No flaming.. I know its not code and im a electrician to boot but heck, Do you ever see a mechanics car run right???
    17000 Gallons (16x32) Vinyl In Ground Pool
    Sand Filter
    Install "Finish Date" July 30 2014"
    Propane heater installed.. Used for 1 day.
    City Water.
  20. Back To Top    #20
    May 2009
    Jasper, TN
    249
    Craigslist is an excellent source to post looking for someone to do this kind of work too. Or at lest just the trenching part.
