Results 1 to 9 of 9
Thread: is low CYA harmful to a vinyl liner?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,323
    Because CYA acts as a buffer to chlorine...does that mean that little to zero cya is bad for a liner
    as the chlorine is then "more harsh." or is it less harsh to swim wear and skin more than anything else?
    I had CYA of 30 just before winter started...I have zero now due to lots of rain and having to
    drain down to keep the fill level correct.
    Very curious about this since my liner is brand new.
    I've ordered more cya to get it back up again.
    I keep my chlorine levels always between the recommended 2-6ppm for a cya level of 30
    since 30 works best for me (pool mostly shaded)
    Dolphin E10 Cleaning Robot.
    JoyfulNoise's Avatar
    May 2015
    13,207
    If you maintain the proper FC/CYA ratio, then no it's not since the hypochlorous acid level is the same. The problem is, when you get to low CYA levels, it's harder to maintain a smaller FC value.
    Your liner should be fine. It has to be exposed to really high active chlorine levels (shock values) to be worried about liner colors fading.
    Matt
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,323
    Re: is low CYA harmful to a vinyl liner?
    thanks Matt, that makes sense.
    May 2015
    13,207
    You could just switch to dichlor chlorination until your CYA builds up.
    And, you very likely have some CYA in the water. The Taylor test is hard to read below 30ppm.
    Matt
    Aug 2014
    Northern IL
    4,615
    Dichlor is not a fave around TFP because it adds CYA and you need to be able to account for that in your calculations. However, that's what I use for CYA additions. (I was lucky enough to buy a 50# pail of granules a couple of years ago. Now, you may have to buy 1# bags). EDIT: Pails are still available but the prices vary significantly.
    I keep my CYA at low levels so if it drops a tad, I can't measure it accurately. A bit of dichlor for FC instead of bleach works a treat until my CYA once again registers. Then I switch back to liquid chlorine.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,323
    I spent 100's of dollars one season to correct 300+ cya (water rates where I used to live were highway robbery)
    on my last pool.
    So now, I hate pucks on principle, but 'might' use them if I'm ever away for a week vacation.
    Aug 2014
    Northern IL
    4,615
    I bought my granules (NOT pucks) for $2/#. Granules allow you to add only exactly what you can measure and they are quickly measurable.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,323
    wow where did you get them that low of a cost?
    Aug 2014
    Northern IL
    4,615
    Sam's Club sells 50 pound pails for $109.99. (I paid $99 a few years ago). However, they only carry it in season. I checked an Ocala, Florida Sam's Club and they have it in stock now. Maybe the Northwest stores will stock it in Spring. http://www.samsclub.com/sams/chlorin...uestid=1479434
